JMB RetrofitsAH Fabrications
    Nov 2012
    York
    20
    3.0 TDI Quattro Springs
    Hi
    Was wondering if someone could advise on suspension springs on my A4 Quattro 3.0 TDI.
    When I bought the car a few months ago the previous owner had fitted lowered springs (30mm lower front and rear), the car looks well but unfortunately I live in a place with speed humps practically every road and the under side of the car scrapes on them if I haven't gone slow enough, so need I need to change them back to standard.
    I have found a used set but they are off a 2007 B7 model, will these fit my car?
    Apr 2009
    Coventry
    2,219
    Definately not.To put oem springs on, you would need to know the axle weights both front and rear.There are a dozen if not more variations for the B8 alone.Its that stupid that even depending on what options you have on the car depends on what springs are fitted....its all to do with weight.Best go to the dealers with your VIN or reg and see if they can tell what weight it was and maybe what springs were fitted at factory.
    In fact, it would be interesting to know if the weight stated on your reg doc is generic or actual....either way it would give you an idea.Im sure a few kg either way wont make much of a differance
    Pass me my sock
    Want to help cure cancer? http://folding.stanford.edu/English/HomePage
    Nov 2012
    York
    20
    Thanks for your response. I will see what springs where put onto my car originally
    Apr 2009
    Coventry
    2,219
    no probs.good luck!
    Pass me my sock
  1. Rear spring on 2.5 TDI Quattro sport avant
    By spartacus68 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th August 2012, 21:54
  2. Audi A3 8L Quattro TDi Standard Springs
    By Geoff-R in forum For Sale/Wanted - Audi Parts
    Last Post: 23rd February 2012, 14:02
  3. 2.5 TDi Quattro hopeful speculation?
    By bsharp in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2003, 13:01
  4. Turbo noise - 1997 1.9 Tdi Quattro
    By Holywood in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th August 2003, 15:36
  5. 1997 A4 1.9 Tdi Quattro - turbo noise
    By Holywood in forum The Welcome Section
    Last Post: 26th August 2003, 15:10
