Badger5JMB Retrofits
    Nov 2012
    S Wales
    11
    Fuel flap not opening
    I am having problems opening my fuel flap and I have to resort to using the pull cord which is on the inside of the boot. Once I have released the flap it functions ok but next time I go to fill up I am back to square 1. It will not open by pressing the flap from the outside no matter what. Anyone else had this problem before?
    Mar 2010
    Suffolk
    7
    I had the same problem. I found I could open the flap by literally banging the flap at the rear end. If it doesn't open the first time bang again and eventually it opend. Once opened it worked perfectly. However it returned to the non-opening mode next time I needed to open it when I had to repeat the same brutal opening method.
    Good news is it now is working fine. I suspect the locking solenoid mechanism gets sticky but I didn't investigate any further.
    Nov 2012
    S Wales
    11
    Thanks for the reply, I am not sure I want to copy your method of opening it tho The pull cord operates fine without the need to bang but I was hopeing for a bit more response to be honest. I will use some wd40 on the switch to see if that helps,
    Thanks anyway
    Dec 2012
    Gateshead Angel of the North
    Use your central door locking press lock then open 2 times till you here it klick it opens with that I had same problem
    27,120
    With the flap open, when you lock & unlock the car, does the solenoid slide in/out ok properly?
    Nov 2012
    S Wales
    11
    Thanks guy's. It is working fine now. I pressed unlock twice and I could hear the solenoid click into action and when pressing the flap it opened first time. It must have been out of sequence or something?
  1. Fuel Cap Not Opening
    By sid812 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 1st January 2012, 18:10
  2. Fuel gauge not working correctly A6 2.5TDI
    By K7ERG in forum Classic Audi Forum
    Last Post: 16th April 2007, 20:10
  3. boot will not open help!!
    By pottsey in forum Classic Audi Forum
    Last Post: 19th June 2006, 20:01
  4. Fuel flap sticker - useless dealer
    By Amchlolor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st March 2006, 14:24
  5. Bad Fitting Fuel Flap
    By Boyakasha in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd December 2005, 12:16
