Sky InsuranceAH Fabrications
Results 1 to 18 of 18
    Audi Dynamik's Avatar
    Sep 2011
    1,968
    Question Why will my Car not work on Rolling Road ?
    Hello,
    I attended the Yorkshire Rolling Road Event today in my 2011 A4 2.0tfsi Dynamik Quattro (Revo Remap)
    I got onto the 4wd Rolling Road and for some strange reason my Front wheels would not spin they were attempting to move but could not, the Rear Wheels only span.
    I still want to attend a Rolling Road again sometime to get some figures for my car but can somebody tell me, Why did my front wheels not spin on my Quattro A4 on the Rolling Road ?
    Any input welcome.
    Her 2011 Limited Edition A4 Dynamik 2.0 Tfsi quattro 211 BHP Saloon & Mine 2013 Bmw 535D M Sport 313 Bhp 630nm.
    Reputation given for the best answer.
    Jenkobenko's Avatar
    Jan 2012
    Swansea
    61
    Isnt Quattro these days intelligent? so it will drive with only 2 wheels until it senses it needs the 4 aka. you thrash it about?
    Sep 2011
    1,968
    It is a Quattro but apparently the a4 is a permanent 4wd and has not got a haldex.
    riggssuzuki's Avatar
    Jan 2012
    Elgin, Scotland
    439
    Damn. I was waiting with baited breath for the results!!! You are quite correct the A4 does not have the haldex. Cant think why you couldnt run if it was a 4 wheel rolling road. Did the operator not have any ideas?
    2011 A4 2.0 TFSI Quattro Dynamik. IBIS White.
    Sep 2011
    1,968
    I know sorry pal ! He had no idea why ? They checked for fuses and things but no luck. Just wouldn't go.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    edl kicking in, prob need to remove abd fuse to cure it
    Sep 2011
    1,968
    Quote Originally Posted by Byzan Pics View Post
    please can you explain this to me ?
    Feb 2008
    107
    Never known a Quattro needing fuse removal.
    Worst might be to disable the ESP - did they try this? I've never had any further mechanical or electrical modifications required to run.
    Sep 2011
    1,968
    A few of the cars which were there like s3's Quattro needed there fuse removing for it to work but this was not required for the A4. They tried it with esp on and off. The front wheels were attempting to spin but couldn't and the back ones were running but the back right one were running faster than the back left.
    Feb 2008
    107
    Sorry, by Quattro I was not including the electronic jiggery used on A3 etc. it simply becomes fwd with Haldex disabled.
    Any other permanent AWD cars there which were successful?
    Sep 2011
    1,968
    Yeah, Audi S2, Audi S3's.
    michaelg1001's Avatar
    Apr 2012
    Sheffield
    99
    My B5 S4 and the B4 S2 I think were the only permanent 4wd ones that ran successfully. The only S3s that ran were 8Ls
    _G_
    _G_'s Avatar
    Jul 2011
    869
    pull the abs fuse it will disable the edl.. still wondering if it is low differential fluid or a wheel speed sensor fault though... hmmm
    could always use VCDS to perm disable EDL and ASR but leave ABS on.
    Sep 2011
    1,968
    Right thanks for the advice everyone
    Jan 2012
    Elgin, Scotland
    439
    Any updates?
    Sep 2011
    1,968
    Quote Originally Posted by riggssuzuki View Post
    Any updates?
    The Electronic Differential Lock (EDL) permits smooth, comfortable starts on road surfaces that do not have a uniform coefficient of friction. If a wheel starts to spin, EDL brakes it as necessary so that power is transmitted to the wheel with the better traction. EDL reduces tire wear and works up to about 25 mph (quattro®: up to about 50 mph). EDL is part of the Electronic Stabilization Program (ESP®) and the Traction control (ASR).
    What i guess is now that because the Car has edl the abs fuse needs to be taken out for it to work successfully on the Rolling Road or use a VCDS to disable the edl meanwhile it is running on the Rolling Road.
    Gavin0478's Avatar
    May 2010
    cleveland
    443
    I am sure i read somewhere that for a true 4x4 dyno the rollers front to rear need to have a mechanical link to take out any effects of front rear bias and to truly imitate a normal road condition as surly if you have a normal rear bias and in effect different resistance front to rear all power will be sent to the slower turning axle.
    V8 baby... oh yeah
    Gavin0478's Avatar
    May 2010
    cleveland
    443
    V8 baby... oh yeah
  1. Replies: 0
    Last Post: 14th January 2012, 12:28
  2. Light swich and auto dim mirror inside car not working. A4 avant s-line 2004
    By audimannen in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th October 2011, 13:08
  3. Why does my aerial not work?
    By AjM in forum In-Car Entertainment
    Last Post: 15th July 2011, 17:38
  4. Replies: 6
    Last Post: 18th April 2011, 18:15
  5. Passenger side dipped beam will not work..Help!
    By jgfrazier in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th October 2008, 19:06
