Volks AutosBadger5
Thread: VAG codes, VCDS
    Sep 2012
    Leicester
    27
    VAG codes, VCDS
    Hi there
    i'm still a complete newbie to all this. i have a 2011 a4 2.0 tdi black edition in white. Absolutely love it to bits first audi i've owned. I was hoping someone could help me out with some information regarding the VCDS? what is this? how does it work? I've seen some enhancements you can make to your car such as the needle sweep with this using codes, and how do you find someone in your area who has this, what are the costs and etiquette in getting to them and getting what you want on your car?
    Also what are the best mods that can be done via VCDS?
    I'm a total newbie to this so apologise in advance if it is totally basic. Help would be much appreciated
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,323
    Hi, welcome to audi-sport.net. Vcds alowws you to check your car for faults, it also allows you to enable extra functions on your car. If you wish to buy vcds cable, user NHN supplies these, you would need to pm him for details. If you just looking for a scan, there is a map in the vcds section of the forum with local users, just find one in your area and pm then. Enjoy the forum. x
  1. vag codes for a4 rns-e in 8l a3
    By nick1973 in forum In-Car Entertainment
    Last Post: 19th January 2007, 09:34
  2. helps with some vag codes!!!!!
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th November 2005, 19:46
  3. Help! VAG CODE 00561 - Mixture Adaption limit not reached
    By imported_ChrisCardiffA3T in forum VCDS (formerly VAG-COM) forum
    Last Post: 20th March 2005, 18:02
  4. Help with Vag code?00561 - Mixture Adaption limit not reached - Interm
    By imported_ChrisCardiffA3T in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th March 2005, 09:44
  5. HELP WITH VAG CODE! O2 SENSOR?
    By 97AUDIA418TQ in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th February 2004, 12:22
