Monster MotorsportChris Nott
Results 1 to 8 of 8
    Mar 2013
    Darlington
    A4 Avant Rear heater controls
    Hi Guys, Have just purchased a nearly new A4 Avant 2012, 2.0 TDI 143 SE. I wondered if anyone could advise me if the rear seat heater controls/blowers should actually work ? when I set the controls in the rear to max heat/speed, nothing appears to happen. I haven't had chance to ask the dealer as yet so any advise would help prior to a visit this Wednesday. Thanks in advance.
    27,014
    Has anyone actually been sitting on the rear bench when you do this?
    Mar 2013
    Darlington
    Hi, Thanks for the reply. Yes, me. still no output.
    27,014
    Ah ok cause rear seat heaters wont work unless someone's sitting in them & knowing audi, they probably linked occupation sensor to the blowers as well, someone else with B8 can confirm this.
    dubdemand's Avatar
    VAG Addict
    Aug 2010
    Surrey
    405
    Don't think that's the case tbh... our rear vents only work when you manually select the dash vents. In this cold weather the auto setting doesn't often put air through the dash vents so the rears don't do that much.
    will probably be more effective once the weather arms up and the air con is needed as the auto setting seems to cool the cabin down through the vents rather than footwell and dash outlets.
    2009 A4 2.0 TDI (170) Avant S Line Exec. ​Quartz Grey, S Line suspension, Bluetooth phone prep low, AMI, DAB, Symphony III, Leather/Alcantara, rear sun blinds, heated/dimming/folding mirrors and cruise control. Mods so far: BBS LM (reps), needle sweep and dipping mirror on reverse. To come: spacers, rear window tint and badge delete.
    Mar 2013
    Darlington
    Thanks for the advice guys, for the benefit of all I will report back after my visit to the dealer later today.
    Mar 2013
    Darlington
    Hi, you were correct dubdemand, the mid facing dash vents need to be active for the rear heating/cooling to work effectively. Many thanks for the time spent replying guys.
    Mar 2012
    Re: A4 Avant Rear heater controls
    But has anyone experience of the temperature dial actually doing anything though? It makes no difference in my car. And never known it work in anyone else's
  1. a4 avant rear light bulbs
    By jimk04 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th December 2004, 19:41
  2. Help ! Climate / Heater Control Problem
    By RICHARDJC in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th November 2004, 14:01
  3. Help ! Climate / Heater Control Problem
    Last Post: 20th November 2004, 14:00
  4. Manual heater control
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th April 2004, 22:29
  5. heater control valve
    By humlicek in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th November 2003, 02:36
