Results 1 to 11 of 11
    Dec 2006
    DPF fault can anyone advise me???
    Hello ive been a member for a few years but have only recently come back onto the audi scene.
    I've just purchased a A4 B8 2.0tdi 143 DPF avant and the other day the emissions control light came on, so i drove the car in regen mode and it went out, however two days later it came on again, I plugged it in and it came up with a fault of exhaust pressure sensor. I was looking through my books and service history and noticed the car had a DPF pressure sensor fitted oct 2011 at a audi dealership so I rung them and they confirmed this at that i may be able to get it replaced under warrenty but that there are two pressure sensors on the DPF so could'nt say for sure if it was the one they replaced without doing a diagnostic them selves at a cost of £103! for them to tell me what i had already told them! ive been doing a little research and it appears there is only one pressure sensor and three temp sensors so i'm wondering if theyre trying to pull a fast one???
    any advice/help will be greatly appriciated
    thanks
    May 2009
    south yorkshire
    628
    knowing audi they were trying to pull a fast one . for you to buy the sensor yourself is cheaper than a diagnostic off them . with things like this you either bite the bullet and buy one ,or hope you have a mate willing to let you try his first .
    Dec 2006
    Don't i have to programme the new sensor to my ECU though?
    May 2009
    south yorkshire
    628
    nope ,done quite a few make sure vacumn pipe is clear before fitting new sensor though by blowing air down it . fit sensor,clear faults and force a regen .
    Dec 2006
    thats great thanks, how do i force a regen?
    May 2009
    south yorkshire
    628
    [Select]
    [01 - Engine]
    [Coding-II - 11]
    • Enable Regeneration by Entering 21295.
    [Do It!]
    [Meas. Blocks - 08]
    Select both Groups at once 070 and 075.
    [Go!]
    MVB 070.1: Regeneration Status (xxxxxxx1 = Normal Regeneration active, xxxxxx1x = Forced Regeneration active)
    MVB 070.3: Regeneration Counter/Timer
    MVB 075.1: Exhaust Gas Temperature before Turbo Charger
    MVB 075.2: Exhaust Gas Temperature before Particle Filter
    MVB 075.3: Particle Filter Load
    MVB 075.4: Exhaust Gas Temperature after Particle Filter
    Now Start the Driving Cycle and keep watching the Measuring Blocks (2nd Person required).
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    if yours is a common rail you can do the regen without driving it .
    best read here easier than explaining it all .
    Diesel Particle Filter Emergency Regeneration - Ross-Tech Wiki
    Dec 2006
    Sorry i don't have VCDS i only have a basic scanner
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    By looking at live data using VCDS for example, not scanner, it's fairly easy to diagnose if the sensors are working. I'd look at having this done before you spend money on a sensor.
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Mar 2012
    Re: DPF fault can anyone advise me???
    It does need to be adaptored though and programmed that way?
    Sep 2013
    24
    It needs to go on VCDS, most garages charge about £35
    If the sensor needs replacing then it needs to be adapted too.
    Where about in the UK are you?
    Nov 2010
    346
    Mine was exactly same. Turned out to be the sensor. £85 fitted at Vastech in Northallerton.
  1. ABS Fault can anyone help
    By DenCar in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th March 2011, 17:44
  2. 2.5TDi Turbo removal - can anyone advise??
    By Chrisavant in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th April 2010, 21:57
  3. Can anyone advise on service cost ?
    By peter02 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th January 2008, 08:19
  4. Can anyone tell me what these fault codes are please?
    By cha1n in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd July 2006, 13:16
  5. Can anyone decode these fault codes?
    By cha1n in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd July 2006, 11:22
