Sky InsuranceEM Tuning
    Mar 2012
    Clicking clutch pedal
    Hi all, my car has decided to annoy me with another noise! The pedal is making a really loud clicking noise! Does anyone have any ideas to solve it? I only had a new one fitted a couple of months ago. Would it be fair enough to take it back to the garage to have a look, or is the pedal nothing to do with the parts disturbed when changing a clutch? The noise is exactly the same as this video here: YouTube
    Sent from my GT-I9100 using Tapatalk 2
    Jetset's Avatar
    Dec 2011
    64
    Stick your head in the footwell and push the pedal down with your hand, I think the noise you refer to may just be the back of the clutch panel catching on the carpet when pressed down and it flicks it when you let it out. Mine did this when I had a steering shaft joint replaced. The back of the pedal has a little piece of plastic which catches the edge of the carpet.
    Worth a look before taking it back
    2012 A3 (8P) Sportback TDI 170 Quattro
    2009 VW Tiguan Sport 4MOTION
    2008 A4 (B8) 1.8T FSi 160 S Line - Gone
    2010 Volvo V50 D3 - Gone
    2009 A3 (8P) Sportback 2.0 TDi 170 - Gone
    Mar 2012
    Re: Clicking clutch pedal
    Thanks for the reply. It's definitely not the carpet from what I can see. Would I have grounds for taking it back then? Or is the actual clutch pedal not touched when changing the clutch and it's just a coincidence and nothing to do with their work?
    Jetset's Avatar
    Dec 2011
    64
    I would take it back, got to be something to do with it
  1. Clutch pedal.... click, snap, drop!
    By markyp2002 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2009, 00:01
  2. Clutch Pedal - Stuck
    By necroeire in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2005, 20:04
  3. Clutch pedal sticking
    By monty77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd February 2005, 14:58
  4. clutch pedal vibrating
    By imported_kris_tdi in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th September 2004, 21:12
  5. 1.9 TDI Serious Clutch Pedal Vibration
    By matt_splatt in forum General Technical / How To
    Last Post: 13th April 2004, 22:53
