JMB RetrofitsEM Tuning
Results 1 to 12 of 12
    Sep 2011
    Wigan (UK)
    A4 B8 Foglight bulb
    Can anyone tell me how to remove the Fog lights on my 58 plate A4 B8 S Line. So I can replace a broken bulb, Stealers want a small fortune. would be grateful for any info Please.
    27,097
    Foglights do you mean?
    Sep 2011
    Wigan (UK)
    Yes fog not spot, Sorry.
    27,097
    Pull the fog trim of 1st & then its screwed onto the bumper, simple job & remove bulb from rear.
    Sep 2011
    Wigan (UK)
    Cheers, Ill have a go this weekend. Thanks
    scoTTy's Avatar
    Essex, UK
    1,958
    Be careful in cold weather like this. It's probably worth warming the grill plastic with a hair drier first.
    A few people have snapped the tags off. The other way is that apparently you can get to them via the wheel arch if you move the liner out of the way....although I just grabbed and yanked the grill (in warm weather).
    MY2010 B8 A4 Avant 2.0TFSI quattro S-line Executive
    Honda CBR1100XX Super Blackbird
    Gone : B6 S4 (AMD stage 3), TT (APR), Golf GTi, CBR600F
    redspudder's Avatar
    Sparky
    Jul 2008
    Middlesbrough
    365
    Quote Originally Posted by scoTTy View Post
    I found it easier to go in through the wheel arch,turn your wheel so you have access and then remove x2 torkscrews from the inner arch lining and then bend it back enough to fit your arm in,the power connecter has a small indent to push to release it from the lamp holder,once this is removed twist the holder and it will come out in your hand with the lamp attached,the new unit should come with the small holder and lamp attached and then just reverse the process.
    I changed mine for white fogs a few moths back to match the xenons and DRL's.
    2.0Tdi 170 Black Edtion Avant
    Feb 2011
    Kent, UK
    17
    Quote Originally Posted by redspudder View Post
    Ooh. Do you have a link for the what bulb you replaced with? I think my wagon looks a bid naff having 'yellow' foglights, and nice white headlights!
    riggssuzuki's Avatar
    Jan 2012
    Elgin, Scotland
    444
    Quote Originally Posted by toadusmodus View Post
    White fogs are great for 'the look' but yellow beams cut the fog much much better.
    2011 A4 2.0 TFSI Quattro Dynamik. IBIS White.
    Sep 2011
    Wigan (UK)
    Didn't need to replace the fog light bulb, when I removed the wheel arch protector I found out that the bulb & the holder had not been replaced properly from having the cam belt done last month. The bulb was still working & very worryingly for the last month I've been smelling burning plastic as I use the Go home lights this time of year. So I've found the source of the smell ( the hot bulb resting on the plastic) & fixed the bulb for free. Wish most repairs where this simple.
    27,097
    Damn, thats nasty, easy fix though huh.
    Sep 2011
    Wigan (UK)
    Thanks for all the info everyone.
  1. S6/A6 side indicator bulbs
    By Kevshann in forum General Technical / How To
    Last Post: 7th July 2003, 19:00
  2. silverfusion bulbs....?
    By rockstar in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th June 2003, 17:40
  3. Civic Headlight bulb removal??
    By Naresh in forum Other Brands & Models
    Last Post: 26th June 2003, 13:12
  4. Philips silver vision bulbs - picture
    By lewy in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2003, 12:45
  5. Clear Indicator Bulbs
    By Moresauce in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2003, 01:17
