Results 1 to 7 of 7
    Jun 2012
    Scottish Highlands
    Visit Reidy's Youtube Channel
    S-Tronic --- Tiptronic
    Evening folks
    Can anyone tell me the difference from a s-tronic gearbox and a tiptronic gearbox from looking at it as i am bit puzzled or can anyone tell s-tronic gearbox codes i have A4 2009 TFSI and was told it was a s-tronic when bought just had gearbox oil changed and they tell me i have tiptronic
    cheers reidy
    Oct 2012
    Warrington, North West
    953
    Not 100% mate but I think tiptronic refers to the paddles
    26,720
    Tip is a 6 speed & stronic uses a 7 speed, do some searching on google or the like, plenty of same questions asked there, also just ask if yours is 6 or 7 speed, stronic afaik has always been 7 speed.
    mylo911's Avatar
    Jan 2013
    23
    Tiptronic is a conventional automatic gearbox, S-Tronic is a twin-clutch automated manual gearbox (still classed as an automatic).
    S-Tronic replaced DSG (direct shift gearbox) which was first introduced in the Mk1 TT 3.2, and uses one clutch for even gears and another for odd.
    Hope this helps
    Feb 2008
    107
    I believe the term DSG is still used in VW vehicles whislt Audi marketing considered Stronic to sound more exec and thus command a higher premium
    As Mylo said -
    Stronic is in effect an "auto clutch" manual gearbox, with some electronic self shifting. It features simultaneous disengage of a gear whilst engaging the next - via the mentioend dual clutches.
    Tiptronic is an auto shift with torque converter etc. yet with ability to shift up or down a gear at driver request.
    I believe DSG or "Stronic" boxes have been offered in both 6 and 7 speed variants, though perhaps not on all models?
    AjM
    AjM's Avatar
    Living in Blissful Ignorance
    Jan 2007
    Torbay, S.Devon
    277
    As the last to really. Tiptronic is the name for a CVT box that can be manually changed whereas S-tronic is the Audi name for VWs DSG and is described very well above. If your A4 is 2009- it will be S-Tronic As 08-09 is when they finally brought S-tronic to the A4. You can also tell from the gear selector as well as they are very different in appearance in the A4 (though of course not fool proof method).
    mylo911's Avatar
    Jan 2013
    23
    Quote Originally Posted by AjM View Post
    Continuously Variable Transmission (CVT) is known as Multitronic, and is vastly different to Tiptronic, and S-tronic. There is no physical change of gear, because it is a chain that slides between two cones, so fundamentally has no gears. It does however have a number of pre-programmed gears that you can change into manually using the gear lever or paddles behind the steering wheel.
  1. Tiptronic chip
    By AndyHolmes in forum Tuning
    Last Post: 9th April 2004, 13:20
  2. A4 1.8T Ultra Sport- auto tiptronic Paddles?
    By metroaudi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th December 2003, 03:51
  3. TipTronic shifting
    By banjo_guru in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th September 2003, 16:53
  4. Tiptronic steering wheel
    By TheTonsta in forum General Technical / How To
    Last Post: 31st August 2003, 18:57
  5. A6 Avant 2.5tdi quattro sport Tiptronic
    By jyeoman in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 24th August 2003, 16:39
