Chris NottBadger5
Results 1 to 12 of 12
    Nov 2012
    FBMFSW for vehicle with dynamic steering
    I wanted to fit a FBMFSW to my S4 but sadly it wasnt as straightforward as it first seemed.
    My S4 has dynamic steering and this means that the factory steering wheel has flat spots and grooves at 3 and 9 oclock on the reverse of the steering wheel as shown in the following picture.
    The replacement FBMFSW I purchased from eBay shown in the following picture does not have the flat spots and grooves therefore it does not fit. It seems all FBMFSW on eBay are like this and do not have the required flat spots and grooves for dynamic steering.
    I have scoured ETKA to try and find the right part number for a dynamic steering compatible FBMFSW without success.
    Can anyone of you help me please?
    Meanwhile I have emailed Europrice in the US and HazzyDays in the UK for guidance.
    Audi S4 B8 Avant in Ibis White with all options and Trups LEDs
    27,114
    Can you show me a pic of the front of your wheel please.
    I have a complete brand new fbmfsw that has the correct fixings yours require.
    Nov 2012
    Here is a shot of the fbmfsw which doesn't fit.
    Do you have pictures of the item you have please if it's for sale?
    27,114
    I meant a pic of front of your original wheel.
    Nov 2012
    Sure
    27,114
    Ok leave that with me, as thats not the latest version wheel, what years your S4?
    Nov 2012
    September 2009 Original steering wheel is pn 8K0 419 091 BF
    Many thanks in advance for your help on this NHN.
    Nov 2012
    I've been advised that the flat spots are not required, the wheel I have will work, it will just push the plastic tabs out the way in the vehicle. During initial fitment this did not feel comfortable at all.
    I'll try a re-fit on Tuesday night and see if I can get it working.
    The only alternative is an S4 facelift wheel which has the cutouts and flat spots and would fit perfectly but that would mean selling what I have in-hand already.
    27,114
    Which plastic tabs, when you remove your wheel next, take a pic & post it as I've not had an issue, also note facelift wheels have different wiring, so you may have to change other components to make the newer style button arrangements work fully or at all.
    Nov 2012
    There are black plastic tabs on the slip ring.
    NHN I have seen the requirement mentioned but not the procedure. How would I go about removing the connector from the TT FBSW I have and fitting the factory connector in its place?
    From the following pictures you can see that the airbag connector on the FBMFSW is not the same as the factory connector.
    Factory airbag connector
    FBMFSW airbag connector
    Nov 2012
    Turned out fine in the end, the FBSW does fit in the gap but pushes the plastic tabs on the slipring out the way so it was all ok.
    Installed and working perfectly now.
    27,114
    Pics of the tabs of the steering module?
  1. My FBMFSW for your FBMFSW (with paddles)
    By guffy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th March 2009, 01:36
  2. For those with Sat Nav
    By Platinum70 in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 18th November 2005, 22:34
  3. for those with DSG and Tdi power
    By marriedblonde in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th March 2005, 08:26
  4. Audi A4 Symphony headunit for sale with radio code
    By imported_Tariq in forum In-Car Entertainment
    Last Post: 25th October 2004, 23:40
  5. Anyone fancy a custom Milltek for A3 with S3 Bumpe
    By nfluester in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2004, 10:31
