Volks AutosAH Fabrications
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Daggerit
Thread: Radiator fan staying on
    AshA4's Avatar
    Ash
    Sep 2004
    Newport, South Wales
    193
    Question Radiator fan staying on
    Hey guys quick Q?
    Just been out for a short drive, didn't tank it took it nice and steady (ave 42mpg) pulled car onto drive and turned her off.
    Noticed the radiator fan stayed on, temp gauge in car was just below half way and it is 7.5 deg outside temp.
    Fan stayed on for about 5 mins, I am guessing this is normal but I have not noticed it on my car before?
    Would expect this during high summer temps but not in winter?
    I did search but found nowt
    B8 A4 Avant 2.0 TDi 143 | S-Line Executive | Lava Grey | Privacy Glass - Auto Dim/Fold Mirrors
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    901
    Quote Originally Posted by AshA4 View Post
    Hey guys quick Q?
    I can't see your sig because I'm on my phone but I'm assuming you have a diesel... As far as I can make out that's a DPF regen interrupted as mine does this as well (3.0 TDi). Nothing to worry about I'd say mate.
    Daytona Grey A4 3.0 TDi Quattro S-Tronic Black Edition
    AshA4's Avatar
    Ash
    Sep 2004
    193
    Yes mate 2.0tdi
    What is a DPF Regen?
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    901
    The diesel particulate filter (DPF) gets clogged up with the soot it's stopping coming out the exhaust pipe and so the regeneration cycle cleans it out by burning them off. If your normal driving doesn't do it, normally by higher revs for a decent amount of time like on a motorway, then the car will automatically adjust the fuelling to create higher temperature exhaust gasses and carry out regen 'manually'. It still continues after the car is off as far as I know.
    What exactly the fan does for this once you turn the car off I don't know but it seems to continue fuelling so maybe it's to keep it cool or something? I also notice a slight burning smell at the same time...
    AshA4 likes this.
    AshA4's Avatar
    Ash
    Sep 2004
    193
    Cheers mate, knew what the DPF was but now know a lot more.
    Makes sense too as I did baby the car on that run, thanks again
    Apr 2012
    49
    Is the burning smell like burning rubber? if so, mine does that!
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    901
    Quote Originally Posted by @ndr3w View Post
    Yeah a little bit actually!
    a4sline's Avatar
    Oct 2004
    land of Strongbow
    185
    Another DPF giveaway is, was the car running at about 1000rpm at idle before switching off ?
    If so was in regeneration, along with fans and burning smell, probably regen.
    It's in the DNA
    Apr 2012
    49
    Quote Originally Posted by Daggerit View Post
    Thank God for that!
    It happened the other day and the missus said I must have been going round corners too fast! Cheek!
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    901
    Funnily enough mine did this again when I got home and it definitely smells like burning! Haha.
    Mar 2013
    IRELAND
    Help!!! Audi a3 2.0 tdi
    My Audi A3 has a few faults and im trying to work out if its worth keeping or get rid??
    1. The fan keeps kicking in and seems to be getting worse, not overheating temp stays at 90.
    2. Diagnostics says theres 7 faults,
    3. Loud whistle when driving, especially when giving the boot! not modified!!
    4. New sound now when boot is applied, and losing power....
    PLEASE HELP, thanks,
  1. Radiator fan comes on & stays on!
    By madpirie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th September 2009, 19:36
  2. Question on 2.0tdi sportsback radiator fans
    By JasonM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th July 2006, 18:56
  3. Radiator Fan
    By rudyno9 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th May 2005, 12:28
  4. Radiator Fan
    By rudyno9 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th May 2005, 11:33
  5. Audi 90 CS Radiator fans quit
    By jlmata in forum Classic Audi Forum
    Last Post: 2nd June 2003, 15:19
