AH FabricationsSky Insurance
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    Grill options...
    Morning everyone,
    Just a quick question but one that I feel I may not get a definite answer for.
    I'm fancying the RS4 grill for the car but in the optics as I think that it will match the fog surrounds and looks awesome. The questions is though, will the facelift RS5 grill fit? Because the new RS4 is so new I've never seen them side by side or anything. I'm assuming that if the normal A4/S4/A5/S5 facelift grills are interchangable then the RS versions will be as well?
    Anyone have any experience with these?
    Cheers guys!
    Dan
    Daytona Grey A4 3.0 TDi Quattro S-Tronic Black Edition
    Feb 2008
    RS5 Grille will fit - ie opening dimensions are the same however it's not a simple bolt in replacement. I believe the mounting tabs are in slightly different locations on the 5 vs 4 bumper layouts. Seen a couple of them fitted - so it can be done, however needs a bit of modification and not sure how much that entails.
    So if oem isyour preference - go with an RS4, or if you're happy aftermarket, maybe try and get the paint code for the alu-optic finish and redress a cheaper option?
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    Grill options...
    Thanks for this! Just wanna double check you're speaking about the facelift as well?
    Feb 2008
    Doh, no, sorry was pre - oversight on my part.
    I'd drop Alex at Europrice a line -
    contact@europrice.us
    I know he was getting some early test fitting a week or two ago and believed the RS5 would NOT fit an A/S4 on the facelift variants. He may well now have definitive findings either way.
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    Grill options...
    Quote Originally Posted by Spr0cket View Post
    Cheers boss!
  1. S3 grille options to remove awful badges!!!!!!!!!!!!
    By gaznogaro2003 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th December 2010, 09:16
  2. front grille options for DIY
    By shawn9766 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 29th June 2010, 03:45
  3. door blades and grill options
    By Jason-Con in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th March 2010, 13:11
  4. 09 Facelift Grill Options
    By A3_SSS in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th June 2009, 10:34
  5. Pre-Facelift Grill Options?
    By Don76 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th September 2008, 18:22
