Sky InsuranceChris Nott
Thread: the roof rails
    MIMechE's Avatar
    Sep 2012
    19
    the roof rails
    Are these a permanent fit, or can they easily be removed?
    2012 A4 Avant Black Edition 177ps
    Soft lad's Avatar
    May 2010
    133
    I assume you mean the Avant, if so, apparently there are only 4 or 5 bolts but you have to remove the head lining. Audi wanted about £700 labour as I guess it has something to do with Airbags too
    26,722
    If you mean the roof bars fitted to some cars, then yes they're semi permanent as in if you remove then you have some nice holes to weld shut, flatten, paint etc, so in that respect more permanent than not.
    johnnythepie's Avatar
    handcrankywannkyspanky
    Apr 2009
    Coventry
    2,174
    Just out of interest, why do you want to remove them? There are four bolts that attach each rail.Curtain airbags have to be disconnected I guess hence the labour costs...£700 labour is about four hours work at my local stealer....Id go to a VAG independant if you want them off
    Pass me my sock
    Want to help cure cancer? http://folding.stanford.edu/English/HomePage
    26,722
    TBH you may get away with not removing the curtains, they can be moved aside & maybe undo 1 bolt, but certainly lining removal.
  1. Calling all Avant owners, polishing the roof rails
    By duffy78 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th July 2012, 02:30
  2. The Audi is now sporting some sexy roof rails :)
    By AudiAndy21 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th May 2012, 19:47
  3. Giving avant roof rail the alloy look
    By redevo1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th November 2008, 21:58
  4. S4 Avant Roof Rails
    By shagga in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th February 2005, 17:36
  5. chrome roof rails
    By chester2000 in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th August 2004, 20:39
