Sky InsuranceEM Tuning
Results 1 to 14 of 14
Thread: AMI Retrofit
    Sep 2012
    Edzell Woods, By Brechin, NE Scotland
    AMI Retrofit
    HI Folks
    Just had an AMI i pod retroft done at an independant garage,
    Probems with the aux socket now not working and the i pod will not play (unit i bought had no instructions as I thought it was only plug and play)
    The i pod just will not allow me to play anything, the CD player and radio still works but not the aux socket or i pod.
    It comes up with componenet connected.
    Is there a software update required for this or anything else I need to know that we have to do to get this to work
    Cheers Hopefully yours
    Brian (
    26,716
    What coding have they actually done?
    Sep 2012
    not sure but will ask the guy tomorrow and get back to you.
    Is there a new code you need to insert to activate the AMI unit ?
    Cheers for reply
    Brian
    Jan 2012
    1,593
    AMI Retrofit
    Quote Originally Posted by bimilne View Post
    Cheers for reply
    Brian
    It would be helpful if we knew which system this was fitted to.
    MMI 2G/3G/Concert/Symphony etc???
    Sep 2012
    Symphony 6 disc CD player with media button and a 3.5mm jack for i pod just now
    Brian
    Jan 2012
    1,593
    AMI Retrofit
    When you connect the iPod does it light up and charge?
    If you press MEDIA on your HU and select source from one of the inner keys what does it bring up?
    Sep 2012
    the i pod lights up and looks like its charges ok. On the i pod it comes up "accessory connected"
    When I press media on the HU it shows the Aux lit up but it does not play the i pod when connected to the 3.5mm jack. The SD card outlet and the CD are not lit up but the CD does play, I havent tried the SD card
    Brian
    Nov 2008
    389
    AMI Retrofit
    Bit confused - if iPod connected via ami why is 3.5mm jack involved?
    Work: A3 Sportback Black Edition 2.0TDI Home: A4 Avant 2.0 TDI Quattro S-Line
    Sep 2012
    only said about the 3.5mm jack as it now does not work, since the guy fitted the AMI it has for some reason stopped any i pod/i phone playing through that jack
    Nov 2008
    389
    AMI Retrofit
    If Ami Etc coded correctly then iPod should definitely just appear under media and just work . Perhaps although AMI physically installed and powered - car needs coding to say Ami present?
    I know what I'm talking about fitting AMI in A3 but I'm sure B8 A4 still needs some coding...
    Mar 2012
    27
    I have AMI in a similar set up to you.....just to add, I don't think you can have the 3.5 Aux as well as the AMI, it's either or, when getting AMI fitted it will disable the 3.5 Aux socket.
    This is what I was told when fitting anyway, my car was an early B8 so didn't have the socket anyway.
    Apr 2012
    49
    I would be interested in getting my AMI updated for my iPhone. How do I go about this?
    26,716
    When you say updated, doesnt yours work atm?
    Jan 2012
    1,593
    AMI Retrofit
    I'm confused - too many queries in one thread!
  1. Retrofitting AMI, is it possible?
    By ryanstewart9 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th July 2012, 22:53
  2. Retrofitting AMI into RNSe (2011)
    By Cruiser89 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st December 2011, 05:22
  3. AMI RETROFIT TO RNS E 2010
    By Stotty in forum Satellite Navigation
    Last Post: 20th March 2011, 11:31
  4. S3 AMI + RNS E Retrofit cabling help needed
    By Boab01 in forum In-Car Entertainment
    Last Post: 7th January 2011, 15:57
  5. Audi A8 AMI retrofit ( for MOST )
    By HJW12 in forum A8/S8 forum
    Last Post: 8th November 2007, 16:05
