Volks AutosBadger5
Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By NHN
Thread: Audi a4 steering controls and airbag problem
    Jul 2012
    13
    Hi people
    I did got myself an audi A4 (b8) Avant a few months ago, and I have a few problems.
    the 1 st one is on the steering wheel, the controls for the audio don't work and they don't light up.
    the 2 nd problem it's with the warning light for the airbag being on all the time.
    I have been informed that this may be related to a fault on the clock spring .
    does anyone had the same problem? or have any suggestions before I take the car to the stealer!
    thanks.
    27,099
    Slip ring could be faulty or the airbag loom maybe have been unplugged, needs diagnosing, was it bought from audi?
    Jul 2012
    13
    Hi
    not from Audi, it was from a car dealer.
    the car only had 21k miles at the time.
    27,099
    How long you actually had the car from them?
    Whereabouts in the country are you, as I could look at it for you location dependent.
    Jul 2012
    13
    ok, i have some logs with the errors
    Address 02: Auto Trans (J217) Labels: 0AW-927-156.clb
    Part No SW: 8K0 927 155 B HW: 0AW 927 156 E
    Component: 0AW 20TDI RdW H05 0004
    Revision: --H05--- Serial number: 0000000098
    Coding: 000002
    Shop #: WSC 06335 000 00000
    ASAM Dataset: EV_TCMVL381 A01014
    ROD: EV_TCMVL381_AU48.rod
    VCID: 326104116534409
    1 Fault Found:
    2225 - RPM Signal from ECU
    P0727 00 [236] - No Signal
    MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 6
    Mileage: 47075 km
    Date: 2012.09.21
    Time: 09:58:09
    Jul 2012
    13
    another one:
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
    Component: AirbagVW-AU10 H26 0410
    Serial number: 0038JD15DZ4F
    Coding: 30363434363030303030554A3052384B3053
    ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 3C7D2A29B770869
    Crash sensor for side airbag; driver side:
    Serial number: 6334MSME27023A4EF
    Crash sensor for side airbag; passenger side:
    Serial number: 6344MSME390232070
    Crash sensor for side airbag; rear driver side:
    Serial number: 6352QSME67290A0DO
    Crash sensor for side airbag; rear passenger side:
    Serial number: 6362QSME67262E59T
    Crash sensor for front airbag; driver side:
    Serial number: 63732SME7177146B0
    Crash sensor for front airbag; passenger side:
    Serial number: 63832SME70421871U
    5 Faults Found:
    9440027 - Driver's side; side-airbag igniter
    B100B 1B [136] - Resistance Too High
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 34158 km
    Date: 2010.04.05
    Time: 17:54:14
    9439771 - Front Passenger's Side Airbag Igniter
    B100A 1B [136] - Resistance Too High
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 34158 km
    Date: 2010.04.05
    Time: 17:54:14
    9444885 - Driver's seat position sensor
    B101E 15 [136] - Open or Short to Plus
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 34158 km
    Date: 2010.04.05
    Time: 17:54:14
    9445141 - Passenger's seat position sensor
    B101F 15 [136] - Open or Short to Plus
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 34158 km
    Date: 2010.04.05
    Time: 17:54:14
    9447189 - Seat Occupied Sensor; Passenger's Side
    B1027 15 [136] - Open or Short to Plus
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 34158 km
    Date: 2010.04.05
    Time: 17:54:14
    Jul 2012
    13
    and for last the steering:
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
    Component: Lenks.Modul H12 0013
    Revision: -------- Serial number: 90304HEH00064
    Coding: 000013
    VCID: 3D7B272DA46A8F1
    1 Fault Found:
    01426 - Controls in Steering Wheel (E221)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 22
    Reset counter: 221
    Mileage: 1048574 km
    Time Indication: 0
    Jul 2012
    13
    the one that most scares me is the gearbox, any ideas?
    thanks.
    27,099
    Thats a fake/clone/counterfeit cable.
    Jul 2012
    13
    i don't know, it was done by a friend that works at skoda!
    27,099
    Sorry I cant help further because of the cable, get a genuine or scanned with genuine & I'll be happy to help further.
    Jul 2012
    13
    you wont help me because he did use a clone/fake cable,? or because these results could be wrong?
    27,099
    This forum does not support the usage of counterfeit cables, given Ross-tech give free help to users when possible & thus we should respect them as a company that produces such a great tool, to support users with counterfeit cables shows disrespect for them & thus puts at risk there support for the forum as such which for allot of members is worth allot more to them, other vag forums also take this stance & tbh much harder actions.
    As a genuine seller of the cables, I do not support usage of the chinese counterfeits & therefore cant offer further help until such time you utilise a genuine cable, sorry but I'm sure you can understand the logic of myself, why should I support people that can afford nice cars, but use chinese knockoffs which not only puts there cars at risk but tbh is money down the drain eventually.
    If you can utilise a genuine interface, feel free to post up the log again & I amongst others would be happy to help when we have the time.
    johnnythepie likes this.
    Jul 2012
    13
    I didn't know that he used a fake cable, I left the car with him and he send me an email with the errors.
    I understand your point, but why should I pay now £100+ at Audi, to get the same diagnostic?
    If anyone else wants to help I’ll appreciate.
    I just don't want to get ripped off be the dealer, and get a repair bill for something that don’t need to be replaced.
    27,099
    With respect, running these cars isnt cheap anyway, vcds isnt just to get your log, it will help you to find the cause, clear the errors, test, recode etc etc, lots of functions & your mate tbh shouldnt be putting counterfeit cables onto your car as you never really know what effect it may have, what if he shutdown or caused more problems, what would your responce be to him then, he should as a hopefully responsible skoda technician, know not to use chinese knockoffs on other peoples cars, whose to say he hasnt caused any of those codes, food for thought.
    Depending where you are, I would of looked at it for you, but as he's a tech surely he can resolve the issues for you?
    Jul 2012
    13
    you are right, but i understand more about Ants than cars.
    I'm in Jersey (channel islands), he's a car seller not a tech.
    thanks anyway for you time and help.
    27,099
    Thats even worse, salesmen messing with technical stuff isnt the best idea, unless they were a former technician.
    Hey I'd go anywhere if I was paid, Jersey is closer than some of my UK jobs lol.
  1. AUDI B5 S4 LEATHER STEERING WHEEL AND AIRBAG
    By LeeT in forum For Sale/Wanted - Audi Parts
    Last Post: 30th November 2011, 18:19
  2. Voice control and Bluetooth problems...
    By welshwoody in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st June 2011, 00:37
  3. Need help with pics of steering wheel and airbag
    By moogie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th July 2007, 21:28
