Sky InsuranceJMB Retrofits
Page 1 of 3 123 LastLast
Results 1 to 40 of 89
Like Tree7Likes
Thread: Interior LED Conversion (pic heavy!!)
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    Hey all,
    Just thought that I would do a quick write up of my internal LED conversion that was supplied by t8ups. I know there have been a few of these but I don't think that any have shown you how to change each type and from a customer perspective rather than the supplier explaining.
    First off the delivery was amazing - paid yesterday afternoon and the LEDs were at my door first thing this morning. Very professional.
    Ok, on to the actual work...
    I was very nervous about trying to remove the large frosted section of plastic as I didn't want to scratch anything so decided to start with the map lights. Here the lights are standard.
    From there I unscrewed the Torx screw in the suglasses holder
    and gave the unit a little tug for it to come away from theheadlining.
    From there I let it hang down and removed the first map light by turning the holder 90 degrees and pulling it out
    From there all you have to do is pull the old bulb out and pop in the new LED and refit. I found I had to angle it going in but no issue with clearance once you do that.
    Here is the comparison:
    Next I pushed the main light festoon bulbs out and unclipped the frosted section from behind, there is one of these on each side and I thought that was much better than attacking it from the front to save scratches and such. I just popped a screwdriver behind it and it popped right off.
    From there it was easy to pop in the new LEDs
    The next stage was just a quick re-assembly and the first lights were done!
    Next I decided to attack the rear map lights which started looking like this
    Just a gentle pry off from one end with the screwdriver and the housing popped off no problem
    The next part is easy, just pull out the old bulbs and fire in the new LEDs!
    Next was the glove box, and all it takes is to pop the screwdriver under the end and it comes out. From there just pull (quite solidly!) on the connector and it will come off to release the bulb housing assembly so you can play with it and get the bulb out. The little white plastic housing comes off with a small clip on each side which I just put a screwdriver under to gently get off.
    Lastly I popped in the new LED
    and you can see how amazing the difference is straight away!
    The footwell lights, boot, puddle lights and the active reflectors are done in the same way as the glove box. Admittedly the rear fotwell lights were a bit of a pain in the butt, that said I managed to get them changed within 5 minutes each. A quick shot of the active reflectors since it's still a bit bright for puddle light demos. The front is the LED (if you couldn't tell).
    Here you can see the difference before and after with the footwell lights!
    The very last ones I did were the vanity mirrors.
    These were similar to the ones above in that all you have to do is pry them up at one side, remove the internal cover and put in the new LED festoons.
    The whole operation took about 30-45 minutes and was much, much easier than I thought it would be! I'm very impressed with the way the LEDs look and the quality of the work on them, especially the footwell lights.
    I'll try to get some pictures once it gets dark too.
    Thanks t8ups for the LEDs and answering all my random questions!
    Daytona Grey A4 3.0 TDi Quattro S-Tronic Black Edition
    Jan 2012
    1,837
    Excellent upgrade - well done!
    Audi Dynamik's Avatar
    Sep 2011
    2,121
    Looking very nice well done !
    Her 2011 Limited Edition A4 Dynamik 2.0 Tfsi quattro 211 BHP Saloon & Mine 2013 Bmw 535D M Sport 313 Bhp 630nm.
    ***Audi's In The Park***The Biggest Audi Event In Europe 10th August 2014*** http://www.audi-sport.net/vb/audis-park-aitp-2014/221933-audis-park-2014-show-10th-august-billing-aquadrome.html
    Reputation given for the best answer.
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    Here you go guys. Unfortunately it doesn't really do justice to just how bright they really are! It's amazing the difference.
    redspudder's Avatar
    Sparky
    Jul 2008
    Middlesbrough
    365
    Daggerit Thanks for the write up thats quailty,i have been looking at doing this for ages and asked Tups for a price on the lamps only yesterday,i will print this out and fit at the weekend.
    2.0Tdi 170 Black Edtion Avant
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    No worries, I'm glad it could be of use.
    I found the rear footwells were a PITA to get out and was quite aggressive so it might be nice to start there so you know everthing after them is easier. One this I will say is to always check they work before fully refitting them in case you have the LED the wrong way round or anything.
    If there are any questions or anything feel free to PM me.
    redspudder's Avatar
    Sparky
    Jul 2008
    Middlesbrough
    365
    I dont have interior lighting pack so no puddle lights or glove box ligh t28K car and its an optional extra, even the wifes new Fiesta came with footwell and glovebox light cheers Audi
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    Quote Originally Posted by redspudder View Post
    What about vanity lights?
    I completely agree, I can't believe I had to choose it as an option! That said, I'm really glad I did now...
    redspudder's Avatar
    Sparky
    Jul 2008
    Middlesbrough
    365
    [QUOTE=Daggerit;1684967]What about vanity lights?
    After seeing your write i was like hmm what about the vanity lights,and i cant say ive ever looked!!I will have a look when i go home tonight.
    Have you changed your number plate lights to LED or does the face lift model come fitted with them now?I had a right chew getting the holders out but once i had mastered it was a piece of cake to do, changed them not long after i bought the car.
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    Yeah, I think that you only get them with the light pack which is a load of balls to be honest!
    Amazingly enough, the facelift models get LED numberplate bulbs as standard! Nice that they've finally caught up with every other 'premium' car brand!
    Jun 2011
    Wellingborough
    1,169
    Dan,
    Thanks for the kind words on the service, i will always help as much as i can.
    Great write up, i will send this link around if other members need help fitting.
    KrAzY K likes this.
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    Quote Originally Posted by t8ups View Post
    Dan,
    My pleasure, easy to give credit where it's due!
    Sep 2012
    Re: Interior LED Conversion (pic heavy!!)
    How much does this cost? With out the lighting pack?
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    I think you'd be best just dropping t8ups a PM and he should be able to sort you out!
    Jul 2012
    43
    You'll need to retro fit some of the missing lights before you can use the LEDs.
    Glove box light retro fit and puddle light information
    Audi A4 B8 Door Warning Light and Puddle Light retro fit
    I don't know if anyone has retro fitted the vanity or footwell lights yet.
    On order: A4 Avant 2.0 TDi Quattro 177 Black Edition Daytona Grey
    Tech Pack High, Nappa, Phone Prep High, TV, Heated Seats, Light Pack, Hill Hold, Storage Pack, S-Line Sus
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    I think from the way his post sounded he just wanted to replace the lights he already had rather then retrofit new ones for the light pack... I could be wrong though!
    I like you're choice of car as well Hesl!
    Sep 2012
    Yeah just the existing lights.
    Jun 2011
    Wellingborough
    1,169
    Does it have the light pack?
    Jul 2012
    43
    Quote Originally Posted by Mucking View Post
    I'd say not
    Sep 2012
    I've not got it yet but correct no lighting pack
    riggssuzuki's Avatar
    Jan 2012
    Elgin, Scotland
    444
    Am i correct in assuming that interior bulb change to LED does not throw up any bulb warnings?
    2011 A4 2.0 TFSI Quattro Dynamik. IBIS White.
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    Quote Originally Posted by riggssuzuki View Post
    You are 100% correct! No issues at all with them.
    four wheels on the ground
    scotland
    I ordered these yesterday and got them today and had them all fitted in 10 mins very pleased and a super fast service
    Thanks again turps
    Sep 2012
    good job
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    Quote Originally Posted by vangoo View Post
    Thanks again turps
    Yup, awesome service and products!
    Jun 2011
    Wellingborough
    1,169
    Here are the prices:
    Non Light pack - £28 posted
    front dome lights
    front map lights
    rear dome lights
    boot light
    Light pack - £65 posted
    front dome lights
    front map lights
    rear dome lights
    boot light
    glove box light
    4 x footwell lights
    4 x puddle lights
    4x red door warning lights
    The price with postage is to the uk or NI. if you require post anywhere else then please contact me before hand.
    There are a few number plate options too, you can go for a canbus LED bulb for an extra £5 or get the OEM leds with adaptor looms for £45.
    Any questions then please ask.
    Trups
  28. #27
    A3simon's Avatar
    Nov 2006
    Aberdeen
    980
    That's cracking dan I did mine 6 weeks ago before I left its amazin the difference it makes in the cabin. Have you fitted the coils yet
    2009 Suzuki GSXR1000K9 SE in White
    2012 Triumph Speed Triple R in Black
    2012 RS3 in Racing Mica Blue
    2012 A1 TFSI in Misano red (shared with mum)
  29. #28
    ScottishS3's Avatar
    May 2011
    Moray
    1,489
    Thanks for an excellenct post Daggerit! Might be ordering from t8ups soon once I have a look and see what lights I have got fitted.
    2009 Audi A4 2.0 TFSI S line, Misano Red, 19" Black Edition Rotors, RS4 Grille, Sat Nav, AMI, Bluetooth, Phone & Voice Prep, CD Changer, Gloss Pack, Heated Seats, Cruise Control, Electric Folding Mirrors, S line Suspension, Dynamic Boot Spoiler, K&N Typhoon Induction Kit
  30. #29
    Apr 2012
    31
    Not the best pictures, but have to say big improve on the standard lights in the cabin - Thanks to t8ups for the LED's, paid Friday - lights were with me on Saturday, top service. Cheers also to daggerit for the step by step guide, most helpful matey.
    No light pack so didn't take long - boot led was the most awkward. Didnt help I did it when it was just turning dark, although the end result looked more impressive. Just need the fog lights changing now - hopefully t8ups will sort me out
    G][/IMG]
  31. #30
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    Quote Originally Posted by A3simon View Post
    Yeah, just makes the whole thing look a lot crisper and modern I think!
    Coilies are here and should be fitted on Friday/Saturday for firing down on Sunday. You heading down?
  32. #31
    A3simon's Avatar
    Nov 2006
    Aberdeen
    980
    Nope im in dubai.
    Look forward to pics once the coils have settled
  33. #32
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    Nope im in dubai.
    That's a shame, would have been nice to see the RS again!
    I'll have photos up as soon as I can, trust me!
  34. #33
    Jun 2011
    Wellingborough
    1,169
    Does anyone know what the boot door lamp on the Avant is?
  35. #34
    redspudder's Avatar
    Sparky
    Jul 2008
    Middlesbrough
    365
    Hi Tups,i sent the fog light lamps back to you yesterday,i have fitted 55w versions.
  36. #35
    Mcdubber1's Avatar
    Nov 2006
    Near Edinburgh
    237
    Another wee mod for me to do in the future along with fog lights and number plate lights. I need to stop thinking of things to do to the A4 and concentrate more on my mk1 project lol
    I'll revert back to here once I get round to getting them.
    Look forward to seeing your car on the coilovers on Sunday daggerit, you can show me your lights too lol
    2009 B8 A4 2.0 TFSi in Misano Red - Shark Performance Stage 1 - Forge FMIC - Forge Diverter Valve - Eibach Spotline's
  37. #36
    Apr 2012
    49
    Just Fitted Interior, Boot & Number Plate LED's. Also New white fog lights. All bulbs purchased from Trups. Excellent service! thanks mate
  38. #37
    Jun 2011
    Wellingborough
    1,169
    Guys
    These are the OEM plate lamps that are now fitted to the facelift B8, if you have a pre facelift i can supply all for £45 posted to the uk or NI.
    you get the 2 OEM lamps with the adaptor loom made using OEM connectors. will work Error free.
    SLOW REPLIES BETWEEN 22nd - 30th June due to been out the office, please bare with me. Thanks
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
  39. #38
    Jun 2011
    104
    Finally got round to fitting mine. Fiddly little job bending the puddle and door conectors back to get the LED strip in, and those rear footwell lights are right bar stewards. Also two short, PM sent.
    A4 3.0 TDi S-Line Quattro, 7 Speed S-Tronic, Phantom Black, 19" 20 Spoke Alloys, Valcona with Heating and Memory, Tech Pack High, Privacy Glass, B & O, AMI, Parking Advanced & Rear View Camera, Advanced Keyless Entry, Heated Electric Folding Mirrors, Panoramic Sunroof, Rear blinds, Tyre Pressure Monitors, Power Tailgate, Phone Prep Low.
  40. #39
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    Quote Originally Posted by toastyhamster View Post
    Yeah I found that the first couple puddle lights I did took me a while but was then able to crack the out in about 30 seconds after that. The unit is much more robust than I gave it credit for to begin with and then I knew what I was looking for.
    The rear footwell lights are a rear pain, I just ended up forcing them out which actually ended up leaving the black cover behind in the seat and pulling it out after! Haha. There was only enough cable to just connect them and they were overall extremely fiddly and difficult... I'll say as well that this is not becaue of t8ups kit, just that the design from Audi doesn't give any leeway!
  41. #40
    Apr 2012
    49
    Interior lights up so much better with the LED's. Imagine the scene in Close Encounters where the UFO lights up the whole pick-up truck!
  1. Replies: 24
    Last Post: 18th November 2013, 14:55
  2. Interior LED Package installed (PIC HEAVY!)
    By Ash187 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st September 2013, 16:25
  3. Single Grill Conversion Done....V6 S3 Hybrid!!! pic heavy
    By Sarah's A3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd May 2013, 06:32
  4. Interior LED Conversion
    By Smoothie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st October 2010, 13:53
  5. HIDs & interior LEDs fitted pics
    By drewbee in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th February 2010, 23:35
