EM TuningJMB Retrofits
    Sep 2012
    I have a few problem with my A4 B8. Any help would be great thanks
    Hi there guys, I have a 2009 2.0T s line a4 b8 which is on 59plate
    I bought this car off copart last week, so it was damaged.
    The parts are getting sprayed so the car should be on the road this weekend as I do all the work my self.
    The problem am having is that I can't remove the pins from the headlight connector
    how do you remove the pins. Because two weires broke off and the pins are still in the connector. So I need to take the pins out. Does any one know how to do this?
    Pin 1 and pin 2, the two weires came out from them two pins. And what are them two pins for?
    Because the headlight xenon / shutter, LEDs and indicator all work.
    Next problem is, the engine keeps reving up to 1 and then goes down.
    So I will check the spark plug leads etc. engine light did come on but when back off.
    Any one had this problem.
    I did my search before posting any thing.
    I Could only find stuff for older model audi's
    Damage of the car
    Just panel damage.
    Starts/runs and drives
    no air bags gone off
    If I don't make sense am sorry.
    I don't know if I have posted in the wrong place if I have I will remove my post
    Best regards
    ash
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,369
    Welcome to audi-sport.net. Someone will be along soon to help answer your questions. Any pics of the car? Enjoy the forum. x
    Sep 2012
    Quote Originally Posted by Sandra View Post
    Aww thanks yep I got pictures of the car
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,436
    theres a tool you can get to remove the pins
    the revving could be MAF but as the engine light came on there will be a fault code stored in the ECU
    so get it scanned and go from there
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,607
    Search for VAG Terminal Tool in eBay, a must have!
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    27,038
    Buy vcds to start with
  1. Audi a4 b5 problems any help would be great
    By Crazymoesizzle in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd December 2010, 11:21
  2. Few Issues with my new motor....any help appreciated....
    By Funkyfin2000 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th November 2010, 19:57
  3. New member having a few problems!lol
    By CamsA3 20vT in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th June 2009, 17:17
  4. Few problems with my 2007 b7, Please help..
    By jajb7 in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 12th November 2008, 19:07
  5. Few problems with my Audi S8
    By BaldNut in forum A8/S8 forum
    Last Post: 31st October 2003, 21:03
