Hi there guys, I have a 2009 2.0T s line a4 b8 which is on 59plate
I bought this car off copart last week, so it was damaged.
The parts are getting sprayed so the car should be on the road this weekend as I do all the work my self.
The problem am having is that I can't remove the pins from the headlight connector
how do you remove the pins. Because two weires broke off and the pins are still in the connector. So I need to take the pins out. Does any one know how to do this?
Pin 1 and pin 2, the two weires came out from them two pins. And what are them two pins for?
Because the headlight xenon / shutter, LEDs and indicator all work.
Next problem is, the engine keeps reving up to 1 and then goes down.
So I will check the spark plug leads etc. engine light did come on but when back off.
Any one had this problem.
I did my search before posting any thing.
I Could only find stuff for older model audi's
Damage of the car
Just panel damage.
Starts/runs and drives
no air bags gone off
If I don't make sense am sorry.
I don't know if I have posted in the wrong place if I have I will remove my post
Best regards
ash
Damage of the car
Just panel damage.
Best regards
ash
