Results 1 to 9 of 9
    Sep 2012
    58 reg A4 3.0 lt Quattro Faults?
    Hi all new here,
    My son's thinking of buying a 58 reg 3.0 tdi A4 quattro se 6 spd manual with 108k on the
    clock, it's got FSH, i'm a retired mechanic and was wondering if their is anything common
    fault wise to check for.
    thanks in advice all for any info
    Alan.
    Audi Dynamik's Avatar
    Sep 2011
    2,126
    Im not sure about that, Somebody soon will come up with an answer
    Her 2011 Limited Edition A4 Dynamik 2.0 Tfsi quattro 211 BHP Saloon & Mine 2013 Bmw 535D M Sport 313 Bhp 630nm.
    ***Audi's In The Park***The Biggest Audi Event In Europe 10th August 2014*** http://www.audi-sport.net/vb/audis-park-aitp-2014/221933-audis-park-2014-show-10th-august-billing-aquadrome.html
    Reputation given for the best answer.
    Aug 2009
    44
    Think the Op says he is a mechanic not the previous owner. It's like anything, something can go wrong no matter how well it is looked after. I find as long as it has been serviced and had regular oil changes then usually it is only minor things that pop up every now and then.
    Sep 2011
    2,126
    Quote Originally Posted by Bigslope View Post
    My Bad, i was rushing reading it as i was in a rush to watch a T.V Programme haha !
    Pyeman's Avatar
    May 2012
    110
    DPF is the only thing that i cam think of.
    It should be ok if it been looked after.
    B8 A4 Avant 2.7 V6 TDi S-line with extra's. 239bhp and 443lbft & my daily VW Caddy VR6
    Apr 2009
    Coventry
    2,219
    Quote Originally Posted by Audi Dynamik View Post
    That really helped the guy .
    Pass me my sock
    Want to help cure cancer? http://folding.stanford.edu/English/HomePage
    Jan 2012
    1,837
    Quote Originally Posted by johnnythepie View Post
    Didn't it just!
    May 2012
    29
    DPF, clutch/flywheel, egr cooler - loss of coolant.
    Have had bother with them all apart from the DPF so far!
    Aug 2012
    15
    Quote Originally Posted by bbeegl View Post
    Hi all new here,
    Alan.
    Ive had a few now and only thing Ive had issues with is inlet manifold motor which is quite common on the 3.0 and 2.7, when they go wrong it puts the management light on, car still drives fine but light is annoying, they can be taken off and serviced which sometimes is a fix.
  1. 2000 A3 1.8T Quattro - Fault Codes
    By VaulterTim in forum VCDS (formerly VAG-COM) forum
    Last Post: 12th July 2006, 00:54
