    Aug 2012
    6
    Rattling front door trims from bass in the speakers
    Right have had enough of the bass rattles from front door trims
    so next week going to strip down and sort them
    Will keep everyone posted
    Any suggestions welcome
    Apr 2009
    Coventry
    2,219
    I can tell that youre really pissed with the rattles.Hate them myself.make sure you use plastic spatulas to remove any trim to avoid marking them.In the past ive used those polystyrene packing beads to tighten up the gaps between door card and door etc
    Pass me my sock
    Want to help cure cancer? http://folding.stanford.edu/English/HomePage
    Aug 2012
    6
    Quote Originally Posted by johnnythepie View Post
    I am
    Was thinking more like dynamat
    I need to pin the rattles down might put new door speakers in whilst I am at it
    land b&0 tweeters in
    Aug 2012
    6
    Right had a good go at it today with some dynamat ans some double sided dense sticky foam tape
    It is a lot better but not perfect
    I think the speaker is not the best
    also wax oiled all the door lock and central locking as the plastic rattled
    the elec window motor was rattling on the door so I loosened it and put some dynamat behind it
    and in the door and on all the flat metal bits
    Will post pics when I know how from my iPad
    Nov 2010
    346
    My window switch rattles, so I jammed a bit of plastic business card in it to stop it.....
  1. Door trim removal help, not the whole panel just the leather insert??
    By Wobblybox in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th August 2012, 13:32
  2. S3 3 door front door trims
    By munchkincoupe in forum For Sale/Wanted - Audi Parts
    Last Post: 12th December 2011, 22:18
  3. View from the front door
    By Caesium in forum General Chat
    Last Post: 17th March 2007, 06:51
  4. Front door frames scratched from seal
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th March 2005, 18:20
  5. Near side front interior door trim removal advice?
    By Greytop in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th January 2005, 18:49
