I can tell that youre really ****** with the rattles.Hate them myself.make sure you use plastic spatulas to remove any trim to avoid marking them.In the past ive used those polystyrene packing beads to tighten up the gaps between door card and door etc
Right had a good go at it today with some dynamat ans some double sided dense sticky foam tape
It is a lot better but not perfect
I think the speaker is not the best
also wax oiled all the door lock and central locking as the plastic rattled
the elec window motor was rattling on the door so I loosened it and put some dynamat behind it
and in the door and on all the flat metal bits
