Sky InsuranceJMB Retrofits
    50k
    Dec 2010
    eleicester
    44
    xennon bulb replacement
    Hi all
    Just a quickie really, I have a slight problem with my xennon bulb, which seems to go out/off after 30 secs of it being switched on..
    then if I was to switch it off manualy from the stalk back to auto lights then it will come on and go off again, when it goes off i get the message on the display. do you guys think its a loose connection or do i need a replacement bulb??
    audi dealers have quoted £154 + plus 1hr labour to take the unit out and fit
    Have any of you had any of these issues? as a bit of advise would be much appreciated.
    thanks
    Sep 2009
    9
    It's deffo ur bulb, it is trying to start but not fireing up completely, genuine bulb off eBay £65 and it is a pretty simple job to do the bulb, remove the plastic panel with the four bolts across the top then just three bolts to loosen off and one too remove then the hole unit pulls out, hope that helps
    50k
    Dec 2010
    eleicester
    44
    Any idea what the part number is?
    Apr 2009
    Coventry
    2,219
    what car what year?
    Pass me my sock
    Want to help cure cancer? http://folding.stanford.edu/English/HomePage
    50k
    Dec 2010
    eleicester
    44
    A4 2.0tdi sline 08 plate– 2008 onwards
  1. Sidelight Bulb Replacement!?
    By StevieBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th January 2010, 22:20
  2. Centre brake light bulb replacement
    By JohnC in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd December 2006, 21:54
  3. Reg plate light.. bulb replacement?? 2003 Avant
    By imported_larry1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th January 2006, 13:49
  4. fog light bulb replacement?
    By imported_RELOADED99 in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th December 2004, 21:24
  5. dash bulb replacement - is it easy?
    By imported_bpascua in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th July 2004, 13:53
