Chris NottAH Fabrications
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By rabhrab
Thread: Checking engine oil on MMI
    Gio G's Avatar
    Jul 2012
    Hertfordshire
    25
    Hi all,
    New to these forums...
    Someone over at Pistonheads with 2.0TFSI was telling a story of how his engine needed replacing after it comsumed quite allot of oil over a period of time. This got me thinking that I should check my oil. So no dipstick, the oil must be checked via the MMI, under the car settings.. So this is where the fun and games start. Engine is warmed up I go the oil settings says something like "Wait approx 2 mins and switch engine off oil levels will appear" I make sure I am on a flat surface..
    So I turn the engine off, however not fully out on the ignition, go to the oil settings again, says please switch on ignition to configure the car settings!!! So followed the manual, it doesn't work. I have opened the bonnet in hope that it may initiate oil settings - no luck.. Anyone else had this problem? Just want to check the oil level!!!
    Trev241's Avatar
    Mar 2007
    229
    Never had this problem, mine works ok. I purchased the dipstick and although I don't leave it in it's good to be able to check the oil regularly the old fashioned way.
    Trev
    redspudder's Avatar
    Sparky
    Jul 2008
    Middlesbrough
    355
    Quote Originally Posted by Trev241 View Post
    I've been thinking about buying a dipstick,did you get it from Audi,i've never really looked but is there a blank where the dipstick would sit and is it easily accessable??One reason is to check the level and also after service to see if the oil has actually been changed
    Never had a problem with the MMi not showing oil level.
    2.0Tdi 170 Black Edtion Avant
    Trev241's Avatar
    Mar 2007
    229
    Genuine Audi dipstick, got it from the WV/Audi spares place at the bottom of Portrack Lane, Stockton.
    Trev
    rabhrab's Avatar
    Oct 2004
    Central Scotland
    46
    Quote Originally Posted by Gio G View Post
    Hi all,
    This works for me: When engine is warm, after a run, switch the engine off and remove the key fob. Wait for a good two minutes then insert the key fob and turn on the ignition, but not the engine. Then go into the MMI system, car settings, oil level, as before and you should be O.K.
    Hope this helps?
    riggssuzuki likes this.
    AshA4's Avatar
    Ash
    Sep 2004
    Newport, South Wales
    184
    My MMIoil reading was showing just below halfway between min and max the other day.
    So in prep for popping in for a litre of oil to top up tomorrow I thought I would check the oil level after filling my washer fluid.
    First I got "oil information is not available at this time" or similar then it showed the min and max but no level at all as if empty?
    So followed the steps in the manual and now I get the "oil information is not available at this time"
    What a PITA this is, what a crap design, how the hell are you meant to check the level as you are topping up, have seen posts online that say wait a couple of days for it to read!!! What between each top up?
    I want to be able to check as I top it up so I don't overfill it!
    No oil warning lights on dash at all and hood sensor is working?
    Where can I get a dip stick from!
    Help!
    B8 A4 Avant 2.0 TDi 143 | S-Line Executive | Lava Grey | Privacy Glass - Auto Dim/Fold Mirrors
    Audi Dynamik's Avatar
    Sep 2011
    1,966
    There maybe something faulty with your car sensor or something :L
    Ive had a look around, cant seem to find much,
    But would this be any help ?
    Laser Tools 4807 Oil Gauge/dipstick Audi
    Her 2011 Limited Edition A4 Dynamik 2.0 Tfsi quattro 211 BHP Saloon & Mine 2013 Bmw 535D M Sport 313 Bhp 630nm.
    Reputation given for the best answer.
    AshA4's Avatar
    Ash
    Sep 2004
    184
    Quote Originally Posted by Audi Dynamik View Post
    Cheers, was speaking to Audi this morning (while they mugged me off for a litre of oil in a pouch) and the workshop guy said they have one they use for servicing but that it is wafer thin, as the tube that is bunged off on the a4 is very thin so I guess a normal dipstick won’t go down it?
    Think the senors are ok as did the DIS "Set" check with no issues found and the bonnet also shows as open on the DIS.
    I managed to get the MMI to show the oil anyway, after driving to Audi this morning the temp was at 90 on the gauge and on pulling up, even with the engine running it showed the oil, it is about one block from the bottom so I am gonna bung the litre in (half a time) when I get home after letting it settle, that is as long as the MMI shows me it again lol
    Nov 2010
    15
    Does anyone know if there is a dipstick tube on the 3.0TDI? I can't find one. Using the MMI is a pain, I prefer to do when I'm checking the washers, etc.
    AshA4's Avatar
    Ash
    Sep 2004
    184
    MMI showed the oil level when I got home from work, so turned off engine and added half a litre from the top up bottle.
    Put oil cap on and closed bonnet, turned ignition on and MMI showed 3 quarters full (so left at that) it also showed the oil level on the DIS.
    So all is well
    What I will say is it works well as long as the engine is warm (90 on temp gauge) or it complains about all sorts.
  1. Engine oil check problem
    By dragonstyle in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2010, 15:33
  2. Resetting check engine light and ln1
    By VuDuStetson in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st January 2008, 12:44
  3. Checking Engine oil with engine running?
    By Defratos in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th November 2007, 18:27
  4. Checking engine oil
    By Johnytuono in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 25th June 2007, 14:44
  5. check engine light
    By imported_mikee111 in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th November 2004, 09:51
