Monster MotorsportChris Nott
    Jun 2011
    15
    Engine Rev Fluctuating when stationary
    I've been having problems with my AC for the last few weeks, it pumps out warm/cool air, not COLD Air as it should.
    Its going in to the dealer tomorrow.
    But I have noticed one thing over the last few days, if I am stationary for a few minutes with the AC on, every 20-30seconds the rev needle drops a bit, picks up a bit and then back to original position. When this happens you can feel the car slightly shake.
    If the AC is off, it doesnt do this.
    I videoed the Rev needle today to show the dealer, as I guess they may just say "we cant find any fault"
    Not sure if this is related to the AC problem I've been having.
    Anyone else had similar issues with AC? or with the fluctuating Rev?
    Thanks!
    27,075
    Sounds like compressor issue to me.
  1. Revs fluctuating
    By imported_andrewriding in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2012, 21:11
  2. high pitch noise when driving? it gets higher pitched with engine revs
    By danonline in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2011, 19:23
  3. Engine revs up and down when coasting?
    By crispin in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 9th March 2011, 20:57
  4. ENGINE CUTS OUT WHEN ON FULL LOCK AT LOW REVS HELP!!!
    By NIGEL in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th July 2010, 18:42
  5. Noise when stationary and I press the Clutch
    By imported_Smudge973 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th October 2004, 20:09
