EM TuningJMB Retrofits
    Jul 2012
    Angry Driver's side door will not open from inside!!!
    Please help! The driver's side door to my 2009 A4 will not open today from the inside. I can open it from the outside after crawling out from the passenger door. When I lock/unlock from the remote, the sounds sound normal and things are moving within the door. Except the signal lights inside blink twice when they usually don't when I unlock using the remote. The feel of the door handle from the inside is much less resistance than the other doors, feels like something is not pulling?? Also doesn't matter if I unlock using the remote or the buttons inside the door, door still will not open from inside. Help!!!
    Pyeman's Avatar
    May 2012
    110
    Either I'm having Deja vu or there seem to be a lot of door handles not working at the moment for a few people or am I missing something...................................
    B8 A4 Avant 2.7 V6 TDi S-line with extra's. 239bhp and 443lbft & my daily VW Caddy VR6
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,531
    take the door card off and look ?
    27,126
    Interior, exterior handles & remote use a different mechanism to unlock, so do as Bez suggests, remove the door card & check the interior handle cable thats probably come unhooked.
  1. Driver's side door will not open from inside
    By Sunbeam08 in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th July 2012, 08:21
  2. Driver's side door will not open from inside
    By Sunbeam08 in forum Audi S4/A4/A4 Cab (B8 Chassis)
  3. 3 door passenger door will not open
    By I15GOD in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th November 2011, 16:53
  4. Passenger door will not open
    By S3KO4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2010, 23:18
  5. Drivers door not opening from outside.
    By nomadx in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th January 2010, 12:09
Tags for this Thread
