AH FabricationsEM Tuning
    Jul 2012
    Angry Driver's side door will not open from inside
    Please help! The driver's side door to my 2009 A4 will not open today from the inside. I can open it from the outside after crawling out from the passenger door. When I lock/unlock from the remote, the sounds sound normal and things are moving within the door. Except the signal lights inside blink twice when they usually don't when I unlock using the remote. The feel of the door handle from the inside is much less resistance than the other doors, feels like something is not pulling?? Also doesn't matter if I unlock using the remote or the buttons inside the door, door still will not open from inside. Help!!!
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    614
    Sounds like a mechanical fault between the inside release handle and the lock mechanism itself, so door interior trim panel off job IMHO to see what's wrong....
    In the short term might it be easier to lower the window and reach the outside handle that way?
    You might get more replies too in the correct forum, this is for the ancient B5 model A4........
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Cruise / Aircon + Climate / Royale Blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
  1. 3 door passenger door will not open
    By I15GOD in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th November 2011, 16:53
  2. Audi A3 drivers side door lock not working
    By rick28 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd August 2011, 01:35
  3. Passenger door will not open
    By S3KO4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2010, 23:18
  4. Drivers door not opening from outside.
    By nomadx in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th January 2010, 12:09
  5. drivers interior door handle not opening door
    By obitus in forum General Technical / How To
    Last Post: 20th May 2008, 15:52
Tags for this Thread
