Volks AutosMonster Motorsport
Results 1 to 15 of 15
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    881
    3.0 DPF question
    Hey guys,
    I'm picking up the new car later this year as per my sig and was wondering if anyone knows of a company that does DPF deletes for this engine? I'm just not seeing the point of having it in since it's not part of the MOT and even in the future they're just planning on having a visual check anyway unless I'm mistaken so gutting the housing would be alright.
    Also, what is involved apart from getting the actual housing gutted? There is some software to remove the DPF requirement but is this easily done on the new 'locked' ECUs? Does it even get done through the ECU or can it be a VCDS job? Is there any idea of cost for this engine? So many questions! Any help would be useful so I can start looking into it.
    Cheers lads,
    Dan
    Daytona Grey A4 3.0 TDi Quattro S-Tronic Black Edition
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    683
    Hi Dan,
    ECU has to be removed for sure. Essentially the ECU needs to be recalibrated so that it doesn't get frustrated due to the lack of DPF. The problem you have is that your car isn't built yet and so we don't know what kind of software is on the ECU. As it stands, I can do it - but there is a chance that your ECU will come with protected software that will take a few months before it can be accessed. Then again, it might be fine. If you were local I'd say come down and we'd take a look, but it's a long drive if it can't yet be programmed.
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    881
    Hey Rick,
    Thanks for the reply. I take it no one has really done much work on the new B8's then? The only issue I'd have is whether they would then use the ECU modification to squirrel out of warranty claims as well? If you manage to get your hands on another facelift B8 ECU and find it can be done then definitely let me know, it's only a 6/7 hour drive down to you. Haha.
    Cheers,
    Dan
    Jan 2012
    Stockport, Cheshire
    683
    As it stands we can do it. Trouble is, your new car might contain some new tricks
    Rick
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    881
    Cool, thanks Rick. Are you able to PM me an idea of the price for it as it stands so I can sort finances prior to doing it? I understand that if the ECU contains black magic and it takes longer that there may be in increase but just quote me for the work as it stands if you can?
    Cheers,
    Dan
    Jan 2012
    1,599
    Are you not going to consider your warranty before removing the dpf?
    And also are you going to inform dvla that the emissions of the car have now increased?
    Jan 2012
    Stockport, Cheshire
    683
    I believe the OP isn't planning on using the car on the public highway..
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    881
    Quote Originally Posted by A6CR View Post
    Yes I am considering the warranty as well, that's why I've not booked myself in to get it done as I'm not yet 100% sure.
    In terms of emissions though, the DPF can actually increase CO2 due to regen cycles and has no effect on NOx emissions so why would that matter. Since you don't even need one in for the MOT (as of yet...) why would I need to inform the DVLA of anything?
    May 2012
    21
    The reason for a dpf is to reduce particulate emissions which are a know carcinogen and in urban areas in particular increases asthma.
    If you want more performance an S4 or RS4 would be a better choice or just go with a remap and see how that goes.
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    881
    Quote Originally Posted by hmy7k View Post
    Yeah, this I'm aware of. But then the list of things that increase the risk of cancer includes things like shift work, high temperature cooking, steroids, hair salon chemicals and dyes, houshold paint and some cancer treatments! A lot of which people are in contact with on a more regular basis than they are sitting right behind a de-DPF'd A4 tootling about town I'd say. At the end of the day it isn't illegal or anything in Britain and if it was then I'd leave it in. I've never had a de-cat or anything like that which is illegal at the end of the day.
    I don't want an S4 or RS4 because they're more expensive to buy, tax, fuel and much more to insure. I'm not looking at it for outright power either, I think that it would give a bit more response when I need it and better fuel economy which is what I'm after.
    Plus, the S4 and RS4 produce much more CO2 than mine if you're worried about the emissions...
    Feb 2012
    65
    I actually think the DPF technology was rushed into production and over time will be proved wrong. The injection of Diesel into the DPF and effect on daily MPG's causes more harm than good to the invironment as more fuel overall is being burned. Sure a simple 30 second test up the exhuast pipe of a DPF'd car will show lower toxic readings than a non DPF'd car however would the same test show the same results over a couple of months, i believe not and as a result would also like to remove this filter.
    Just my thoughts on the matter.
    Stu
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    881
    Quote Originally Posted by l5tuy View Post
    Stu
    I agree, I think that the regen process is extremely inefficient and they cause more trouble than they're worth. Technology will undoubtedly get better but at the minute they're pretty crap to be honest and cause worse fuel economy resulting in more overall fuel being burned and more emissions as you've said.
    The thing is that particulate isn't tested on current MOTs as far as I know and CO2/NOx levels aren't increased so what is the problem removing it? It's another technology introduced by manufacturers to say their cars are cleaner on paper really isn't it?
    Feb 2012
    65
    [/QUOTE]The thing is that particulate isn't tested on current MOTs as far as I know and CO2/NOx levels aren't increased so what is the problem removing it? It's another technology introduced by manufacturers to say their cars are cleaner on paper really isn't it?[/QUOTE]
    This is more to do with the testing when the new cars are introduced and taxation classes decided, the engine efficiency is tested and road tax based on the result (think this is where A6CR was coming from). However this is where i was coming from with the whole short term test, the DPF is basically holding back all the bad particles then every so often tries to dissipate them by burning even more fuel, not convinced personally.
    Although on the other hand my exhaust tail pipe does appear to be a lot cleaner than previous diesels............hmm
    Stu
    May 2012
    Does the dpf not stop the cloud of black smoke under hard acceleration?
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    789
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    Quote Originally Posted by trance View Post
    It doesn't stop it completely but it certainly does minimise it. Hence the reason I will not be deleting it on my B7.
  1. DPF delete and remap questions
    By Adnic69 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th August 2012, 21:14
  2. DPF Light Question
    By 3DTDi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th July 2011, 09:44
  3. Different kind of DPF question.
    By Dean's A3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th September 2010, 23:57
  4. Drilled or Slotted thats the question?
    By Tweaky in forum General Technical / How To
    Last Post: 23rd February 2003, 00:21
  5. Couple of questions for admin...
    By MickHumphrey in forum General Chat
    Last Post: 2nd January 2003, 17:04
