Jonny, I use 303 products they do a cleaner and then a protector. You will also need a scrubbing brush. Check out Polished Bliss website, there is a section on cabriolet products found on the left hand side of the site. Polished bliss can be found through any search engine.
I'd second the 303 products I've got a A4 cab I've used auto glym before but it was no good. I the brought the 303 stuff the cleaner and protector. I gave thereof a good clean and then protected it with the protector spray. It came up as good as new I was really pleased and the water just beads off now do I defenitly recommend the 303 cleaner and protector
