Sky InsuranceBadger5
    Feb 2012
    aylesbury
    6
    2008 2.0tdi a4 cab misfire
    hi guys
    any advice on what might be wrong with my car would be much appreciated
    to start at the beginning
    car = 2008 "58" audi a4 2.0 tdi cab engine code BPW less than 50k miles
    faults :-
    1, DPF light on dash, loss of power ( dpf removed and software adapted to allow for this)
    2, misfire ( there has been no good period between dpf issue and misfire)
    work done so far :-
    1, diagnostics with vag.com ( no fault codes )
    2, all 4 injectors removed and tested by specialist with no faults found ( replaced with new seals )
    3, live data showed no.4 injector to be considerably different to other 3
    4, injectors swapped no.1 & no.4, problem still at no.4
    5, wiring loom for injectors replaced
    6, compression test showed all equal and good
    7, egr valve removed and checked ( all working when compared to a new one )
    the injectors have been installed and set as per autodata
    please if i have missed something or you have any thoughts on the matter as its doing my head in
    807
    Hi Stu, yours is a B7 Chassis. Maybe worth posting in the B7 section. They dont do a B8 cabrio as far as I know, i think they carried on using the B7 shape until 2009 for the cab.
    Feb 2012
    aylesbury
    6
    ok cool, i thought it was b8 going on years.
    thanks
  1. 2008 A6 2.0TDI rear light cluster problem
    By craigynett in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 28th August 2011, 08:58
  2. 3.0tdi Cab S-Line Quattro.To buy or not to buy???? Advise please
    By RacDave in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th January 2011, 16:14
  3. 2008 Audi A6 2.0TDI Service Light Reset
    By puntoturbo in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th October 2009, 13:53
  4. Aftermarket HID Xenon Kit On 2008 A4 Cab
    By Benpage in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd October 2009, 13:12
