    Dec 2011
    Essex. Near chigwell
    19
    Unhappy Limp mode...... Very frustrated!!
    Hi all,
    This is my first post so go gently on me!
    I have an intermittant problem on my 07 Audi a4,3.0 cab Quattro I can start. Car, thrash it, or drive it normally and it's absolutely fine as lon as I don't turn it off! If I go anywhere and stop turn off then restart within 5 mins the car goes into limp mode. I have no lights n dash or any other worrying noises etc. I once had the emissions light me on the dash and had it put on a computer to see what the fault was.
    It reported two faults:
    EGR valve intermittant circuit flow restriction .
    turbo charger outside parameter circuit A
    Im desperate to fix this as its spoiling a fantastic experience
    You guys are my last chance.
    I hope someone has experienced this before and can point me I the right direction.
    Here's hoping
    Regards
    Mark
    27,099
    Wrong section, yours is a B7.
    Dec 2011
    19
    Sorry. Thanks for heads up ..... Doh!!
  1. Limp Mode/MAF Problem????
    By GarryX in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th August 2005, 11:10
  2. Limp Mode
    By welshdragon in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd February 2005, 09:55
  3. limp mode due to inlet manifold pressure HELP !!!
    By sahk in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th January 2005, 19:39
  4. Going Into Limp Mode
    By johnboy1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2004, 17:55
  5. N75J and limp mode (overboost problems)
    By pure in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2004, 18:52
