Chris NottBadger5
Results 1 to 9 of 9
    Apr 2012
    Bradford
    17
    NEED SOME HELP ASAP
    I NEED SOME HELP AND ADVICE.
    I BOUGHT SOME ALLOYS TODAY FOR MY B8. THE ALLOYS WERE OFF A B6 A4 SO THE CENTRE HOLE WAS SMALLER THEN THAT OF MY CAR. MY RING ON THE B8 IS 66.6MM SO IV BEEN TOLD BUT THE ONE ON THE ALLOYS IS 57MM.
    NOW I REALLY LIKE THE ALLOYS AS THEY ARE THE NEW RS6 STYLE DESIGN. IS THERE ANYWAY I CAN CUT OR WELD THE CENTRE HOLE TO MAKE IT FIT?
    ALSO WILL THIS WEAKEN THE ALLOY??
    NEED SOME ADVICE ASAP PLEASE.
    May 2012
    Norfolk
    118
    Take them to a local machine shop and see what they have to say about them. I have had spiggots machined in the past to get wheels to fit they will make the decision if its safe to do so or not. DON'T attempt to do it yourself it needs to be done properly
    Apr 2012
    Bradford
    17
    Quote Originally Posted by marty.h View Post
    Thanks. Thats what iv been advised.
    But how am i meant to find a machine shop? Is there any around bradford?? Sorry for being a complete idiot :/
    Pyeman's Avatar
    May 2012
    110
    Just be very careful. If they don't know what they are doing, it could reck the rims.
    It would be less hassel if you got some 15-20mm spacers and had the centre machined off the spacer!!
    B8 A4 Avant 2.7 V6 TDi S-line with extra's. 239bhp and 443lbft & my daily VW Caddy VR6
    Mcdubber1's Avatar
    Nov 2006
    Near Edinburgh
    237
    I'm going to have to do the same with my winter wheels providing they fit over the brakes, still got to try that.
    Pyeman: when you say machine the centre off the spacer do you mean the hub part? That would 't be reccomended as the wheel would have nothing to sit on!
    2009 B8 A4 2.0 TFSi in Misano Red - Shark Performance Stage 1 - Forge FMIC - Forge Diverter Valve - Eibach Spotline's
    Pyeman's Avatar
    May 2012
    110
    Quote Originally Posted by Mcdubber1 View Post
    There are lots of cars that don't have centres for wheels to sit on, if you go out and buy some big AP's or Brembo's they don't have centre's. How do you think race cars work!!!
    I had BIG and I mean BIG Alcon's on my old Evo 8 FQ400 and they had no centre's. The wheel will centre up on the wheel nuts. I know loads of people doing it, its a cheap easy fix.
    Viking's Avatar
    Mar 2010
    217
    Quote Originally Posted by Pyeman View Post
    You'd be better having the rear of the spacers bored out to 66mm, not removing the front face where the wheel sits. That's if you're using 57mm bore size spacers. That's what I'd be doing rather than using 66mm bore size spacers and removing the front face to fit a 57mm bore wheel.
    Mcdubber1's Avatar
    Nov 2006
    Near Edinburgh
    237
    It's certainly not something i would do, i just wouldn't feel safe with it like that, especially with my wife and kids being in the car more than me. I've used spacers/adaptors in the past with very little in the way of a hub for the wheel to sit on and experienced serious vibrations through the car.
    If it were me i'd get the wheels machined down!
    Oct 2009
    Bristol
    48
    Quote Originally Posted by SOHAIL View Post
    If you try google "Precision Engineers Bradford" you will find loads of them. I'm not sure who will do it or if they can give advice on how safe it will be - I know I wouldnt advise on how likely safe the mod will be and I run a machine shop. Pick a company with a large lathe if they dont have tires fitted or a large vertical mill if they do. I imagine the bill to be £100-£150 to skim depending on their rates.
  1. exhaust pics need some help guys
    By tracer in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th August 2006, 16:28
  2. Need some help
    By Lunatikx07 in forum Classic Audi Forum
    Last Post: 13th July 2006, 20:23
  3. needs some help
    By HuntsA4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st January 2006, 17:00
  4. I need some help on alloys......And lowering.....
    By imported_tobycruse in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th February 2005, 15:55
  5. Need some help none car related work pranks
    By DaveCav in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2003, 18:39
