AH FabricationsBadger5
Results 1 to 7 of 7
    Sep 2011
    43
    Retro-fit Nav system with SD slots
    Evening,
    I currently have an 8P A3 but im looking at upgrading to an A4 avant. I've seen one I like in my price range with the high spec which I want... The only thing it doesn't have is a sat nav/ multimedia system.
    Now is this able to be retrofitted? And what would I actually need to complete?
    I also would want to get a system with SD slots.
    Ive done a search but haven't come back with anything.
    Feb 2012
    Glasgow
    228
    Ignore me I'm talking mince!
    Jan 2012
    1,837
    if you get a a4 with the hard drive sat nav you will get sd cards on the dash behind a flap with audi multimedia on it along with optional ami in the glovebox
    Sep 2011
    43
    Quote Originally Posted by IanFM View Post
    The one you are after is rns-e if you search for that you will find loads of info!
    I have already retro-fitted an rns-e system to my a3. But with the A4 2009 onwards, it comes with the screen in the dash, surely it's just retrofitting the nav unit in glovebox with SD slots?
    Rns-e system is the whole system including screen which is what I have in my a3
    Jan 2012
    1,837
    ah you want to fit the nav too, unfortunately its more involved than that, you need a new control panel, front dash, glovebox bits, rear modules in the boot etc .. will be the guts of £2k to fit and code .. better to get a car with it installed already
    Sep 2011
    43
    Well I've found the 3G nav system with 2 SD card slot on the bay for £595 which fits as standard in glovebox, I just didn't know what's needed to fit and connect to screen etc. I'm okay with coding as I have vcds.
    I believe all the navigation buttons etc are on the centre console?
    Jan 2012
    1,837
    You'll need the whole control panel down by the gear stick .. not an easy retrofit for basic users
    and if thats the module i see myself on ebay, thats for the a6 which wont fit/work in the a4 as the a4 sd cards are located above climate panel
    trust me, find a car with it already fitted, far easier
    control panel below the gearstick and note the audi multimedia panel above the climate control is where the sd cards go
  1. A4 1.8T Quattro SLine - Retro Fit Sat Nav and Bluetooth
    By FleetwoodRed in forum General Technical / How To
    Last Post: 8th April 2009, 18:00
  2. b5 S4 retro fit nav plus
    By s4mark in forum In-Car Entertainment
    Last Post: 17th May 2007, 17:43
  3. Sat Nav retro-fit
    By shippy in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th July 2006, 22:32
  4. San Nav Plus Retro fit
    By foremansci in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th June 2006, 06:55
  5. Sat Nav Retro Fit
    Last Post: 20th April 2006, 20:56
