Monster MotorsportChris Nott
    Apr 2012
    A4 B8 LED rear lights?
    Hi all,
    I have a 2009 sline A4, i am wanting to change the rear standard lights to LED lights .. Is this easily done, I seem to remember reading that the connection on the lights are different and you need Audi or software for the lights to work?
    Please cans anyone help on this?
    Thanks,
    Craig
    Pyeman's Avatar
    May 2012
    110
    You could just do a search or................................................ ...................
    Read this retro fitting LED tail lights
    B8 A4 Avant 2.7 V6 TDi S-line with extra's. 239bhp and 443lbft & my daily VW Caddy VR6
    Mar 2012
    94
    Look on Audi-zine and audienthusiasts, a fair bit of info, but basically a touch of rewiring and then recoding with VAGCOM will be required.
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    does anyone know if the original wiring alredy in the car be used on led's or is it a must to replace some of the loom>?Ive heard audi has to recode vcds wont do it?
    Quote Originally Posted by wassap View Post
    Full leather/19"wheels/cruise/
    Jan 2014
    12
    Just
    A) replace bulb with led
    B) use vcds to remove the annoying rear bulb error.
    Simple.
    Probably a quick 5 min job. Don't over analyse it!
  1. Sportback LED Rear Lights
    By PTTM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th November 2009, 19:37
  2. LED rear lights..
    By Mikey170 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd July 2009, 12:17
  3. LED Rear Lights on an S3 8L ?
    By dares_uk in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2008, 19:47
  4. B6 Cabriolet LED rear lights wanted.
    By X2JPH in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th November 2006, 21:03
  5. LED Rear Light Clusters
    By haywood in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th April 2005, 18:18
