AH FabricationsJMB Retrofits
    Nov 2011
    248
    Skipping SD card :-/
    ok, this is unexpected. driving in this AM, the music on my SD card started skipping like it was a stuck record. it skipped about three times then the MMI went to a "Loading..." screen then "no playable tracks". i ejected and reisnserted, it was fine.
    what's up, just loose in the port, mebbes? hadn't hit any potholes or such tho, and the card's been used since i bought the car.
    TIA
    Apr 2009
    Coventry
    2,219
    I guess its ust the way it is....my ami doesnt recognise my ipod on a regular basis, so i unplug and connect again and its fine.Id do an error check/defrag on the card with the pc just to be sure though.
    Pass me my sock
    Want to help cure cancer? http://folding.stanford.edu/English/HomePage
    Audi Novice
    Mar 2009
    Suffolk
    381
    My SD card adapter for my PC does the same thing, I guess it's just used too much the connections aren't quite hitting the mark, maybe it's the same with the card reader?
    I've got my NAV running off an SD card, and that seems to be fine.
    Audi Northampton, Audi Ipswich, and Audi UK are rubbish and lack the basic skills of customer service.
    Please read my posts about my experience, and I hope this helps you to make the decision not to buy an Audi 2.0 TDi 170 engine, they are not fit for purpose and the tolerance levels are a joke.
    Apr 2009
    Coventry
    2,219
    Quote Originally Posted by TripleD View Post
    a rub of the gold contacts on the sd with an eraser normally sorts that out.
    Pass me my sock
  1. cam belt skipping a tooth
    By brownie 25 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th September 2010, 19:17
  2. Audi Concert cd skipping
    By AxE in forum In-Car Entertainment
    Last Post: 1st August 2009, 12:49
  3. Skipping 6 disc cd changer - help
    By ghost.s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2009, 09:35
  4. symphony skipping cds
    By imported_kosh in forum In-Car Entertainment
    Last Post: 13th June 2005, 02:53
  5. SKIPPING CD ?????
    By chester2000 in forum In-Car Entertainment
    Last Post: 7th September 2004, 11:49
