Volks AutosMonster Motorsport
    Feb 2012
    34
    Some MP3s Won't Play?
    Hi All,
    Haven't managed to find an answer to this so far. Maybe you guys can help me out. :o)
    I have a number of MP3s loaded onto an SD card. The bit rate, file format and max number of files thresholds are all within limits.
    However, when I try to play some files, they are jus skipped by the MMI and won'r play. No error, then they appear grey on the screen.
    Any idea? The files play fine elsewhere.
    johnnythepie's Avatar
    handcrankywannkyspanky
    Apr 2009
    Coventry
    2,174
    I had exactly the same with an ipod classic...and i ended up getting rid cos the replacement was the same.This told me it was a hardware issue.You should copy your stuff from the sd card into a folder on your hd, then reformat the sd card, and error check.Run your mp3's through foobar to re encode them, and put them back on the card.Failing this, try a new sd card
    foobar2000
    Pass me my sock
    Want to help cure cancer? http://folding.stanford.edu/English/HomePage
    Feb 2009
    Aberdeen
    2,490
    I assume this is an RNS-E?
    Double check the file format of the songs being skipped as the unit won't recognise every file version, and make sure the file names aren't too long (not sure the limit there, but apparently the systems don't like long file names).
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    Feb 2012
    34
    Will give it a go an let you guys know.
    Thanks for the tips!
    Dec 2003
    Clarkston, Michigan USA
    247
    Double check the files with this software called "Mediainfo". You might find out that some are not constant bit rate and are actually variable bit rate and thus the max bit rate will jump higher than the allowed max bit rate. If you just view the files using a normal media player or by using windows explorer they often will not show you the max bit rate. That's why you need the special program to find this info out.
    MediaInfo
    -Dan from Detroit
    2002 A4 3.0 Tip/Quattro/Sport/Premium
    Quattro GmbH front and lower door flares | Powerchip ECU Chip
    Borla Cat-back exhaust | Hyperflow Intake | B7 RS4 Dead Pedal with RS6 Gas/Brake Pedal
    Bi-Xenon Headlamps | S4 Sideview Mirrors | Phatnoise in Glovebox
  1. XCarLink users: Windows software to manage MP3s
    By benw123 in forum In-Car Entertainment
    Last Post: 9th April 2013, 03:44
  2. mp3s
    By Mini-mad-matt in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th September 2010, 13:23
  3. Concert Radio & MP3s
    By borofoga in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th September 2009, 22:11
  4. How do you put your mp3s onto your RNS-E SD cards?
    By Staz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th September 2008, 13:18
  5. 2006 symphony in-dash 6-disc changer... does it do mp3s?
    By ultramodz in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th January 2008, 02:39
