Badger5Sky Insurance
Results 1 to 12 of 12
    Feb 2012
    65
    Retro cruise control re-coding
    Hello,
    I have spent a bit of time searching the forum with no luck so hopefully someone here can help.
    I am looking to retrofit cruise control to my 58 reg tdi but was wondering if I need to get Audi to code it in or can I do it with VCDS? I haven't bought VCDS yet but if it's possible to retro cruise control with it will be a good excuse to buy it I guess.
    Thanks for your help.
    l 5tuy
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,480
    you can do it with VCDS
    Jun 2008
    790
    Are you sure? When I was looking into it, I had come to the conclusion that the B8 couldn't be coded with VCDS, and would require Audi to do this.
    Would love to be proved wrong though.
    Looking for the right A4 Quattro. 1.9 TDI / 1.8T or 2.0T...
    My A4:http://www.audi-sport.net/vb/audi-s4-a4-a4-cab-b8-chassis/125399-my-brief.html
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Don't take this the wrong way but you are proven ;-)
    Cruise Control Retrofitting (8T) - Ross-Tech Wiki
    I would suggest you are thinking of SVM. When Audi carry out a change or retrofit they use SVM (Software Version Management) to do the coding and also update the Audi central computer with the details for the car.
    Stu.
    A4 3.0 TDi S-Line Quattro, 7 Speed S-Tronic, Quartz Grey, 19" Twin Spoke Alloys, Alcantara with Silver Stitching & Heating, Nav High, B & O, AMI, DAB, Parking Advanced & Rear View Camera, Advanced Keyless Entry, LED Interior Light Pack, Hill Hold Assist, Heated Electric Folding Mirrors, Through Load.
    Previous MY11 S3 Sportback Black Edition, S-Tronic, Ibis White.
    bez101's Avatar
    Jul 2008
    8,480
    i saw my mate do his b8 so knew it could be done
    Feb 2012
    65
    Perfect, thanks very much for your help guys. Just found a steering assembly for £40 (used of course) so once I buy a VCDS dongle the cost will equal the £300 Audi wanted, however I will have VCDS .
    l 5tuy
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    Do you mean a stalk assembly? You may be unfortunate and need a Steering Controller / Slip Ring.
    Stu.
    Feb 2012
    65
    Quote Originally Posted by VRStu View Post
    Slip ring with the stalks attached is what I meant bud. Think it may be off an estate though as it has rear wash wipe selection (I think) I'm presuming this function just won't work (I have a saloon) on my car. Do you foresee any probs with using an avant slip ring on a saloon?
    l 5tuy
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    I think you should be ok mate. Just modify the coding so it's not looking for a rear wiper.
    Did you get the lower trim cowling?
    Stu.
    Feb 2012
    65
    No, didn't get the cowling but hopefully Audi won't charge to much for a new one.
    Thanks for you're help bud, us Stu's stick together
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,064
    No problem. Pop back and let us know how it goes.
    Not sure if it's still the case but on the A3 and older A4's the markings for the enlarged opening were in the cowling so you could dremmel it out if that way inclined.
    Stu.
    bez101's Avatar
    Jul 2008
    8,480
    dremmel is the best not seen an b8 one ill have a look tmoro when im at the unit
    save a few ££ if the markings are there
  1. a3 8p cruise control instructions & vagcom coding?
    By fizz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd April 2012, 14:17
  2. Cruise Control - Please can someone check the coding I've found is correct
    By danb986 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd September 2011, 08:58
  3. Cruise Control on 09 B7 - Binary Long Coding ?
    By Masterm8fo in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th June 2011, 14:12
  4. Cruise control coding A3 8P
    By mattandrew in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th February 2008, 17:13
