AH FabricationsVolks Autos
Results 1 to 15 of 15
Thread: Oil Warning :-/
    Nov 2011
    250
    Oil Warning :-/
    just had the car tell me i'm down to the minimum oil level. i bought her in October, put about 2000 miles on since - do the 2.0 TFSI engines go through oil this fast?
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,259
    Depends how you drive. I think most need an extra top up between services. If it was 2000 since last service I'd be worried.
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, S4 alloys, Spacers, Black Optics, Eibachs, RS4 grill and fogs, Fog tints, RS4 ARB, RS4 Gearstick, LCR splitter, Black Calipers, Drilled discs, Debadged, Colour DIS, Bose, Adaptive Xenons/DRL, Black/Silver Audi Exclusive leather, Audi Carbon inlays, carbon difuser/B pillars, RNS-E+/Bluetooth, Cruise, Int/ext light packs, Rain/light sensors, mudflaps, LED plate/side/boot/interior
    Audi Dynamik's Avatar
    Sep 2011
    2,124
    yep i have a Dynamik 2.0 TFSI Quattro i bought it in May 2011 and i have done 6500 miles and i am still using allot of oil, there is nothing to worry about it will be completely normal up to about 7000 miles, if you bought the car From Audi with very low mileage there should be a couple of small bottles of oil in the boot for this reason, i never got any though so i just bought some from where i get it serviced,
    When new they use alot of oil up to about 7000 miles when the engine is fully worn in, it also says in the handbook that it will use alot of oil for the first few thousand mile of having, after about 7000 miles it will still use oil but no as much.
    Hope this helps
    Her 2011 Limited Edition A4 Dynamik 2.0 Tfsi quattro 211 BHP Saloon & Mine 2013 Bmw 535D M Sport 313 Bhp 630nm.
    ***Audi's In The Park***The Biggest Audi Event In Europe 10th August 2014*** http://www.audi-sport.net/vb/audis-park-aitp-2014/221933-audis-park-2014-show-10th-august-billing-aquadrome.html
    Reputation given for the best answer.
    Nov 2011
    250
    just had a call from a guy at the service - says the car can use up to a litre per 750 miles?! wtf, that can't be right surely??
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    No NORMAL engine will use a litre per 750miles, however the manufacturers will often put that criteria in as a bit of a get out clause for engines that dont quite meet tolerance.
    I change the oil in my cars every 5000miles, the Avant is 12 years old and has done 130k, i never have to top it up between changes. Ok it might not still be at maximum after 5000miles, but i've never seen it below half on the dipstick. My saloon has a freshly rebuilt engine which has done about 5000miles since rebuild, and it too doesnt need topped up, because it was run in properly.
    Our previous A4 had 195k on the clock and it did burn oil, approx a litre per 2000miles.
    Engines which have been "babied" for the first couple thousand miles will typically have poorer ring seal and more oil consumption than those engines that have been driven hard from the get go.
    TD5 Land Rover Defender build
    Nov 2011
    250
    i thought the whole point was that you weren't supposed to blat an engine hard UNTIL it had run in?
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,259
    You're never topping it up because you're changing it earlier anyway ...I normally only have to top up near the end of the service interval
    Big Bird's Avatar
    Mar 2010
    81
    My 2009 2.0 TFSI uses a small amount of oil, but never gets as low as the minimum or warning. I just keep an eye on it and top up when. if required. No big deal really.......
    2009 A4 Avant, 2.0T Quattro S-Line, 19" alloys, B&O audio, Satnav, Reversing camera, Milano leather, misano red, light pack, heated seats, bluetooth phone prep
    Honda VFR 800 VTEC - Italian Red
    Crazyfool's Avatar
    Lead boot
    Feb 2007
    South East
    632
    I have bought at least three 4 litre containers of oil since buying the car 2 years ago.
    (59) 2.0T A4 S-Line Avant (B8) Lava Grey
    (N) 2.6 V6 Audi Convertible Europa Blue
    Gone: (02) 1.8T A4 sport saloon (B6) Denim Blue
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,259
    Quote Originally Posted by Crazyfool View Post
    Just for top ups? Seems very high.. .
    A4B8Sline's Avatar
    Jan 2012
    Exeter, Devon
    173
    Mine gets through 1L every 4000miles. Audi says its normal for these engines. Not much you can do about it.
    Jan 2007
    Renfrewshire
    118
    I'm using 1ltr every 1500 miles, I'm now on 21000 miles and it's still doing it! Audi say this is normal eg can use a litre every 1000km or 750, it's a joke really! Mine is going into Audi tomorrow to get rough idle looked at which may help with oil consumption
    A4 Avant 2.0tfsi S-Line Quattro 2010, Misano Red, thinking about bluefin when i have the cash
    Nov 2010
    11
    mine uses 1ltr per 2000miles. According to audi this is perfectly normal and my 2.0Tfsi has done 39K!!!
    Crazyfool's Avatar
    Lead boot
    Feb 2007
    South East
    632
    Quote Originally Posted by razza1 View Post
    I have 4 litres in the garage at the moment. I do a lot of motorway driving. On one occassion, I hadn't realised that the oil was so low and the warning message appeared. I put a litre of oil in and the message wouldn't go away. After an inspection by the mechanic, they worked out that my bonnet catch indicator had broken, so as far as the car was aware, the bonnet hadn't been open and therefore oil wasn't topped up! Complicated or what? After they fixed the switch it was happy again.
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    my 1.8t used to use 1ltr top up between oil changes 10-12 thou
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
  1. S4 4.2 Oil Warning
    By nickb834 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th September 2011, 16:17
  2. Oil Warning?
    By Ronniebiggs in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th January 2011, 20:32
  3. Oil level low warning light - what oil to buy, on xmas day?
    By drewbee in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th December 2009, 11:32
  4. Oil warning light?
    By metricspaces in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2009, 20:00
