DTUKDPM
Results 1 to 18 of 18
Thread: K and N filter
    Jan 2012
    Elgin, Scotland
    142
    Post Thanks / Like
    K and N filter
    Just a quickie. Any benefit to fitting a K and N panel filter or is the OEM one just as good? Do you get increased induction noise? Will i get any improvement in performace as per their advertising bumf or is it all just sales talk?
    2011 A4 2.0 TFSI Quattro Dynamik. IBIS White.
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    870
    Post Thanks / Like
    More noise than anything I think. Standard boxes are good for quite a bit of power. Good noise though :-)
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, S4 alloys, Spacers, Black Optics, Eibachs, RS4 grill and fogs, Fog tints, RS4 ARB, RS4 Gearstick, LCR splitter, Black Calipers, Drilled discs, Debadged, Colour DIS, Bose, Adaptive Xenons/DRL, Black/Silver Audi Exclusive leather, Audi Carbon inlays, carbon difuser/B pillars, RNS-E+/Bluetooth, Cruise, Int/ext light packs, Rain/light sensors, mudflaps, LED plate/side/boot/interior
    Jun 2008
    695
    Post Thanks / Like
    Wouldn't fit a K&N personally. Green Cotton or BMC is where my monies would go.
    Looking for the right A4 Quattro. 1.9 TDI / 1.8T or 2.0T...
    My A4:http://www.audi-sport.net/vb/audi-s4-a4-a4-cab-b8-chassis/125399-my-brief.html
    Sep 2011
    Manchester
    172
    Post Thanks / Like
    does anybody know about the carbonio cold air intake ?
    2011 Brilliant Red A4 Dynamik Saloon Manual 2.0 Tfsi Quattro 305 Bhp 348 lbs/ft Revo Remap fasst, Shell V Power High Octane Premium Performance Fuel.
    Visit my Garage for more Info and Photos
    Jun 2008
    695
    Post Thanks / Like
    They do sound good, but you shouldn't be buying one for power.
    The problem with turbo charged motors compared to NA motors is that the turbo increases the air temperature massively, so the small decrease in temperature from the intake has little effect. You are unlikely to get any more of an increase in power than you would from a panel filter.
    With my old 1.8T I simply installed a Green Cotton panel filter and drilled the airbox. This was just about as efficient as a CAI, made a good amount of noise, and only cost £40.
    I'm not saying you should drill your air box or anything drastic like that, but if you do want to upgrade your air filter, anything more than a replacement panel is really just throwing your money away if your in pursuit of power. If its noise your after, fill your boots.
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    870
    Post Thanks / Like
    Surely drilling your air box is just pulling hot air into your Turbo...can't see how that can be good in any way for the Turbo. ..
    Jun 2008
    695
    Post Thanks / Like
    This was on my mk4 golf, with an air feed to the box from behind the grill. Drilled on the underside, so only cooler air going in. But as the turbo is operating at temps in the 100's of degrees, the air being a few degrees cooler is almost irrelevant.
    Anyway, I did this just for the noise, not for any performance gain. And I am not saying I would recommend it in the Audi, I know I wouldn't be doing it in mine, but then mines is a diesel.
    And I will say, I did get the noise I wanted. And my k03s 1.8T was running a solid 240 bhp and 280 lbft so I know it wasn't doing any harm.
    Audi Novice
    Mar 2009
    Suffolk
    303
    Post Thanks / Like
    Quote Originally Posted by xs2man View Post
    Done this too, and defo agree k&n isn't worth it.
    CAI maybe if you stage 2 you need a it more free flow air, but you'd have to make decent air feeds. IMO I wouldn't bother!
    2012 Audi A4 Dynamik Edition 2.0 TDi 170 Quattro
    warren_S3's Avatar
    Oct 2007
    Undetermined
    4,404
    Post Thanks / Like
    I think replacement panel filter give the illusion of more power but as the same restrictions apply in the pipework and the filter media surface area I have never felt any tangible benefit over paper units which filter better than most aftermarkets.
    I had a Carbonio on my last S3 and I didn't really notice much improvement if I'm honest given the lofty price tag, so I switched to the ITG which opens up the top end of the speedo zone (particularly noticeable on autobahns last year) but again for daily driving doesn't change the characteristics that much for road legal driving. The biggest benefits of the Maxogen are right at the top end of the rev range where the car didn't become breathless like with the awful S3 air intake set up.
    Carbonio
    ITG (Winning no beauty contests!)
    I think the best you can do is smooth or drill air boxes or put direct large bore flex hose feeds into the air box which tend to look unsightly. The OEM filters in the A4's should be more than adequate for the BHP (even mapped).
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    870
    Post Thanks / Like
    What's the smoothing you mention, how is it done and what benefit does it provide?
    Jun 2008
    695
    Post Thanks / Like
    It is the smoothing of the "ridges" that are in the airbox.
    Once these are smoothed, you get less turbulent flow through the box.
    Then you drill the box such that the increased flow still flows through the filter, as well as increased induction noise:
    Of course, you might want to feed cold air to the box also.
    This was a very common mod on the old 1.8T engines. As said previously, I had done it to great effect. Not sure it would really be necessary on the newer Audi's though.
    But as said previously, with your mapped 2.0T, you should only, at most, need to change the filter.
  13. Thanks warren_S3 thanked for this post
  14. #12
    Jan 2012
    Elgin, Scotland
    142
    Post Thanks / Like
    So would I really notice a'nice' noise with a more free flowing panel filter like K&N or pipercross or the like? I am aware there wont be any real increase in power but i like a bit of engine noise.......If i could persuade 'er indoors' I would be going for a Miltek exhaust too but I have to earn many more 'happy wife miles' before i tackle that subject.
  15. #13
    Jun 2008
    695
    Post Thanks / Like
    As I said above, I personally wouldn't go K&N, and Pipercross are as bad. Thid is due to MAF issues I had with my 1.8T many years ago with these filters, so would go green cotton or BMC.
    As for noise, you may or may not notice any difference. If you do, it will only be slight. But it would be more noticeable once you have your exhaust on there.
    I have also previously swore I wouldn't have another Miltek due to problems I had with both my mk4 Golfs and these exhausts. Although the re-sale value of them always seem to bring me back if I'm honest. I think I would be more inclined to go for a custom exhaust though. Stainless Creations down around the Falkirk area make beautiful custom exhausts.
  16. #14
    Jan 2012
    Elgin, Scotland
    142
    Post Thanks / Like
    Wallace performance In Aberdeen do one off stainless exhausts too. Unfortunately the missus will need to be worked on 1st so to speak.....
  17. #15
    Jun 2008
    695
    Post Thanks / Like
    Yeah, that's always the problem. You are not alone.
  18. #16
    Jan 2012
    Elgin, Scotland
    142
    Post Thanks / Like
    Red face
    Hmmm. Anyone know how to remap the missus? Maybe get my Miltek or even a one off stainless system if I can get her to a stage 2.....
  19. Likes Necroscope liked this post
  20. #17
    Feb 2012
    38
    Post Thanks / Like
    Quote Originally Posted by riggssuzuki View Post
    Shoes, prefereably Jimmy Choo
  21. #18
    Jan 2012
    Elgin, Scotland
    142
    Post Thanks / Like
    Ha ha that was the hand bag last year. Price of a flamin Miltek system!!!!!! I think it will be as much as a set of Louboutin shoes...Ouch. Price of a bloomin car!!!! Hey if shes happy, i am delighted (but skint)......... If I wanted the new RS4 I would be donating dangly bits to medical research to pay the bills. Oh well I'm married so I dont need them anyway
  1. Air filter/pollen filter
    By boomtown in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st September 2011, 18:50
  2. How to replace pollen filter and fuel filter?
    By spence_star in forum General Technical / How To
    Last Post: 20th April 2010, 07:59
  3. 2.8 v6 fuel filter location + which air filter
    By audi1664 in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th March 2010, 21:50
  4. Panel filter or Cone filter for dv sound?
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2009, 10:01
  5. Pipercross panel filter upgrade and filter cleaning
    By Gavin Cooper in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th September 2009, 17:27
