EM TuningRevo Technik
Results 1 to 16 of 16
Thread: LED Foglights??
    Jul 2011
    Sampford Peverell
    122
    Post Thanks / Like
    LED Foglights??
    Hi Guys.. Im sure this has been asked before but when i did a search i couldnt find a good answer.
    I am after some LED foglight bulbs to try and match the colour of the DRL's as it looks a bit silly when the Coming/Leaving Home lights come on. Does anyone know what ones would work with no errors?
    Thanks in advance
    wyliss's Avatar
    Aug 2004
    North West
    144
    Post Thanks / Like
    +1
    A4 B7 2.0T FSI S-LINE Akoya Silver, Xenon plus pack, RS 6's, MFSW, Phatnoise, Auto dimming mirror, Light/Rain sensor, Bose, Isofix, Split folding seats, Rear side blinds, Rear window blind, Centre armrest, Auto boot Lid, Cargo parcel net/hooks,Loadliner & Votex Rear Diffuser.
    Essex, UK
    1,809
    Post Thanks / Like
    I just fitted some standard bulbs off ebay. They were white Xenon gas filled and are a great colour match.
    This was 32 months ago so the actual ones have probably changed on ebay now
    B8 A4 Avant 2.0TFSI quattro S-line Executive
    Honda CBR1100XX Super Blackbird
    Gone : B6 S4 (AMD stage 3), TT (APR), Golf GTi, CBR600F
    johnnythepie's Avatar
    winkywonkywaanky
    Apr 2009
    Solihull
    1,452
    Post Thanks / Like
    LED Car Lights & Bulbs, 12 Volt - Super Bright LEDs
    seems to be a popular site in the us
    Jul 2011
    Sampford Peverell
    122
    Post Thanks / Like
    I have sourced some LED bulbs and resistors. I am going to have a go at fitting these on the weekend so will take some pics and update.
    winkywonkywaanky
    Apr 2009
    Solihull
    1,452
    Post Thanks / Like
    interested to know what you use and how they look
    Jan 2012
    Elgin, Scotland
    142
    Post Thanks / Like
    Any updates on your LED foglight fit? Do the resistors go in series with the input? Surprised no one has done a complete unit including resistors (or have they?). Are there no heat issues around using resistors? i.e. surely the resistor heats up?
    2011 A4 2.0 TFSI Quattro Dynamik. IBIS White.
    Jul 2011
    Sampford Peverell
    122
    Post Thanks / Like
    Right. I have fitted these today.. It took quite a while as i had heard about the heat issue with the resistors so i wanted to mount them away from anything that can cause issues.
    Unfortunately i didnt really get many photos (mainly as i kept forgetting!)
    I removed the front bumper which gave me access to everything nice and easily and decided to mount the resistors on the brackets that come from the main chassis leg and join on to the wing.
    (You can see the bracket i mean just under the horizontal wiring loom)
    That way they are not going to cause any issues, Also i soldered long wires to the resistors and taped them to the fog light wiring that runs down from there anyway so nice and tidy.
    To connect the wires to the fog light cabling i just used the supplied connectors as i was getting short of light and wanted to reassemble the car, but i intend to properly solder the wires on to give a better finish soon.
    So basically i just used the bulbs H11 CREE Q5 12V/24V LED FOG LIGHT BULBS UK PAIR | eBay as i know the guy who sells them.. and a pair of 50w 3ohm resistors which he also supplies.
    Here is the finished result..
    im very pleased as i also managed to work out how to use VCDS and code the cornering lights which use the fogs so now they match im much happier.
    The job is probably fairly easy to do without removing the bumper but i had a couple of bits to do anyway so i found it easier to remove it. So if nothing else i hope it gives a rough idea how it can be done.
    KJN
    Feb 2007
    Kent
    48
    Post Thanks / Like
    Great Job, looks good well done, got more patience than me.
    Jan 2012
    Elgin, Scotland
    142
    Post Thanks / Like
    Hi any recommendations for a replacement H11 bulb (Non LED)? I am not going to go with the LED mod. Far too much work and far too little time. I have seen Osram night breakers and Philips X treme. Both look pretty white. I have read that the yellowish bulb as fitted is actually much better at cutting through FOG and rain opposed to the pure white. Not that i use them much and i just fancy the foglight colour matching better to the main beam.
    Feb 2012
    38
    Post Thanks / Like
    Good effort, looks like a good mod!
    Jun 2011
    Wellingborough
    414
    Post Thanks / Like
    Guy's check out my SIG for a full plug and play h11 LED foglamp kit.
    Any questions then please ask.
    Trups
    Ice white halogen festoons - http://www.audi-sport.net/vb/product...toon-36mm.html - ideal for 2009+ A3's.
    Error Free LED fog lamp kit - http://www.audi-sport.net/vb/product...ml#post1452995 - £30 posted
    Jul 2011
    Sampford Peverell
    122
    Post Thanks / Like
    Just a quick update.. After living with these for a few days i decided i didnt like the beam pattern that the bulbs gave out.. So i swapped them for some multi SMD LED bulbs but they looked worse.. So I have ordered some Philips Diamond Vision 5000k Bulbs and will just stick with those (once i have removed the resistors).
    Bit of a waste of time but hey you live and learn.
    Jan 2012
    Elgin, Scotland
    142
    Post Thanks / Like
    I have been reading up on LEDs v Bulbs. As far as I can see LEDs give a better look but bulbs give better performance when it comes to use in fog etc. Also the more yellow the bulb the better the performance in fog. Personally I plan to go for something like an Osram or Philips upgrade. This seems like a good middle ground. Admittedly the LEDs look good but I need the performance of a good bulb. Any recommendations for H11 upgrade bulb?
    Jul 2011
    Sampford Peverell
    122
    Post Thanks / Like
    Like i said in my previous post i have ordered some of the Philips diamond vision 5000k bulbs so i will upload a pic once fitted.
    Jan 2012
    Elgin, Scotland
    142
    Post Thanks / Like
    perfect. Will wait before buying mine.
  1. Foglights
    By iamwhatiammomo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th January 2012, 08:40
  2. Foglights...
    By Jameze in forum Rants & Raves
    Last Post: 6th January 2012, 15:24
  3. A3 VS S3 foglights
    By Chlippo in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th July 2010, 04:05
  4. Foglights
    By imported_ANNANBHOY in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd December 2005, 21:19
  5. Foglights
    By Byzan Pics in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th August 2004, 09:28
