Adrian S FluxJuicy
Results 1 to 11 of 11
    Jul 2011
    Post Thanks / Like
    Question Headlight washer jets/nozzles fallen off!!!
    I've recently noticed that my headlight washers are broken as the end bit that squirts the water back at the light appear to have fallen off! So basically, when you wash the things poke out but then just shoot a dribble of water straight out onto the road!! Is this a common thing with the B8s? I've read that they come as complete units so I couldn't just get new nozzles to cap off the tube? is that the case?
    Also, is there any way to make them poke out so I can check them and look more closely? Can you pull down the flap thing on the bumper or is that a bit dodgy? I have tried but it seems to take a fair bit of force and I don't want to break it! Wondered if there was a maintenance mode like with the windscreen wipers?
    Necroscope's Avatar
    Dec 2009
    232
    Post Thanks / Like
    Get someone to grab it when you spray the screen wash from the safety of the interior of the car
    Essex, UK
    1,809
    Post Thanks / Like
    I could be totally on the wrong track here so forgive my assumption but this happens about this time of year every year.
    It happened on forums when I had a TT
    It happened on forums when I had a B6 S4
    It now seems to have happened with the B8
    I would hazzard to suggest that you check your washer fluid solution strenght.
    Being at the front of the car and hence not getting any engine heat etc it seems that the headlight washers are the most susceptible to freezing. If the tips freeze then the pumps build up pressure against the blockage and can push the tubes off or break something.
    I'm not saying that's what happened here but it does sound like a familiar issue.
    p.s. I mix the Audi fluid at 2:1 ration (i.e. 250mm of fluid to 500ml of water). This has always been fine for me and Audi say it's good to -40C.
    B8 A4 Avant 2.0TFSI quattro S-line Executive
    Honda CBR1100XX Super Blackbird
    Gone : B6 S4 (AMD stage 3), TT (APR), Golf GTi, CBR600F
    S.line's Avatar
    Dec 2011
    81
    Post Thanks / Like
    One of mine gets stuck on the cover. I've posted a thread on it but will be watching this one too...
    Dec 2011
    Post Thanks / Like
    Took delivery of a brand new S4 around 8 weeks ago and noticed when I got to work one morning that the washer was sticking out on both sides. The washer had got stuck on the flap and as soon as I moved it away, it pulled itself in no problem.
    Audi had a look at it and adjusted something, its all fine now....
    johnnythepie's Avatar
    winkywonkywaanky
    Apr 2009
    Solihull
    1,452
    Post Thanks / Like
    definately frost damage.Had it myself.The washer is a kind of hydraulic sealed unit, and when the frost gets it the water expands and pushes the piston out.Once out you can push it back in, but the next time its operated it pops out.about 70 squid from the dealer i believe
    dmaudi's Avatar
    Apr 2006
    Hampshire UK
    188
    Post Thanks / Like
    Posted on the other one about washers
    This can happen if the water in the washers freezes and expands,
    Quite common this time of year if you don't have a high concentration winter screen wash
    A BMW I had lost both front washer periscopes until I worked this out, a few years ago, from then even with 2 trips to the alps and our last 2 cold winters they were fine, but I saw lots of cars with this type of washer jet system with missing covers or erect jets! Last winter
    2011 S4, Sprint Blue, Revo S1 map and SPS mode 4, APR Carbonio S2 Inlet, H&R supersport -30 springs, 19x8.5 et35 wheels, on order: AWE non-res full system, podi boost gauge
    Jul 2011
    Post Thanks / Like
    Thanks for all the replies. I think it must have happened last winter under the previous owner as it's been like it since I bought the car in July - I've only recently noticed as you never see them in action! I always use full strength washer fluid. So the question is how to sort it.
    I assume there's no way of getting them to poke out and stay out so I can take a closer look? And can you buy just the nozzle bits on the end or is an entire new unit required? Not happy about having to spend £140 quid on 2 new units if they're £70 each!
    S.line's Avatar
    Dec 2011
    81
    Post Thanks / Like
    Did you not notice it when u got the car? I know it's hard to notice small things when excitement is taking over the mind!!
    Jul 2011
    Post Thanks / Like
    Nope! Difficult to see what's going on down there and didn't even think about it to be honest! Noticed a few months later but never got round to sorting it out. There a pain in the ar5e from what I can tell and have read on here. Was hoping it'd be a cheapish job to buy new nozzles to clip onto the ends but obviously not
    winkywonkywaanky
    Apr 2009
    Solihull
    1,452
    Post Thanks / Like
    ive just checked my etka and for my 2009 they are 46 squid each.They are one piece jobbies, and are called ' lift cylinders ' (!)
  1. Avant rear washer nozzles
    By Mike B in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th January 2011, 21:30
  2. Headlight washer jets dont work, what could be the problem?
    By VTI_EG_DAN in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2009, 10:21
  3. Washer jets
    By Fast,not furious in forum Parts Requests
    Last Post: 22nd January 2009, 10:48
  4. Heated front washer nozzles
    By Matt in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th December 2007, 19:54
  5. Headlight Washer Jets
    By greski in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th April 2004, 13:23
