AWEsome GTIEM Tuning
Results 1 to 9 of 9
    Nov 2011
    Post Thanks / Like
    Exclamation Zenon head light bulb blown!!!
    Hi, this is my first posting on here!!
    I have got a A4 2008 Sline, i have only had it for 2 months and this morning the front nearside dip beam bulb blew. I nipped to Audi to get it fixed only to be told that it would cost £230.95!! They told me the bulb alone was £115 the rest was labour. Can anyone give me any advise please. I would attempt to do it myself but don't want to cause more damage.
    Many thanks for any replies :-)
    Nov 2010
    70
    Post Thanks / Like
    Ebay bulb
    Jul 2011
    Post Thanks / Like
    This happened to me 2 months after I bought my 2008 S-line... frustrating - not sure these bulbs should be going at 3 years? If you've got full Audi service history and you're not too far out of warranty you might try getting some good will out of them! But I had to get mine done at an independent Audi garage for £200
    I'd be wary of ebay bulbs, make sure they're exactly the right ones as could end up causing you more trouble than they're worth!
    kite's Avatar
    Oct 2007
    East Berks
    470
    Post Thanks / Like
    contact audi CS 0800699888
    There is a known fault on xenon bulbs, should be replaced under warranty
    A4 (b6) 2.5 TDi QS Saloon.
    Nov 2011
    Post Thanks / Like
    Took the car into audi today and they have come back with, it is not the just the bulb that isn't working ! As they put the new bulb in and that doesn't work either. They have kept the car to do further tests. Although they did say it may mean replacing the light unit at a cost of around £1000 Hopefully it could be covered with the warranty we took on it from Morotrway direct but not holding my breath.
    Mar 2009
    231
    Post Thanks / Like
    mine just gone tonite turn the lights off and back on again and it works again foe 5 mins then goes off, does thins mean the bulb?
    kite's Avatar
    Oct 2007
    East Berks
    470
    Post Thanks / Like
    Quote Originally Posted by marv View Post
    Swap the bulbs over, if the problem moves with the bulb than thats the problem.
    You could have a failing ballast..
    Oct 2011
    Newcastle Upon Tyne
    Post Thanks / Like
    Audi labour rates are a joke, if you live in the Newcastle area I'll show you how to change it out safely and dont forget to keep a spare in the boot, you can change D2S out in minutes.
    Mar 2009
    231
    Post Thanks / Like
    i ordered 2 from hidsdirect, i am a machanic so getting bulb out is realy easy
  1. how ridiculous is this? £45 for a head light bulb
    By uS4f in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th December 2010, 08:08
  2. 'Blown Bulb' warning still on after replacing H1 bulb
    By hooley in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2010, 15:07
  3. Bulb blown warning light
    By stevey_boy in forum General Technical / How To
    Last Post: 6th August 2008, 18:29
  4. My zenon warning light
    By DaveCav in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th June 2008, 11:08
  5. head light/bulb question... HELP!
    By NxJxHxCedge in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th May 2004, 12:13
