Monster MotorsportChris Nott
Results 1 to 15 of 15
    audi58's Avatar
    Milton Keynes
    149
    Removal of rear bumper and quarter panel
    Hi,
    I've bought some genuine Audi Parking Sensors, just need to fit them now. Anyone with any knowledge of this, I would greatly appreciate any advice or tips.
    Picture guide would be amazing or am I being too hopeful?
    Thanks in advance!
    A7 3.0 TDI 245 S Tronic --Google Maps Navigation Upgrade - Adaptive Lights - Lighting Pack - High Beam Assist - Tinted Windows - DAB Radio
    Previously Owned:
    A5 3.0 TDI 240 S Line -- 3G Navigation
    A4 2.0 TDI 143 S Line -- MMI Navigation - Tinted Windows - DAB Radio - Heated Seats -
    A3 Sportback 2.0 TDI 140 SE -- Remap (thanks to Shark Performance) -- Tinted Windows -- Chrome Roof Rails -- Full Leather Interior -- DIS Retrofit -- RNS-E --
    Nov 2010
    348
    Remove mud flaps if fitted and rear light clusters.
    Remove the rear bumper three fixings around wheel arch, four fixings on lower edge, one fixing
    through back panel and one retaining pin under light cluster.
    The bumper will pull off rearwards. Its a 2 man job as its only a wobbly plastic skin.
    Mar 2011
    30
    Remove the lower front inside boot plastic cover upwards it just clips out, this is what covers the boot catch.
    Remove parcel shelf, remove 2 x torx screws holding the parcel shelf support, clip out the rear boot light and disconnect the wiring, pull the grey boot side inlays towards the center lifting the liner over the rear anchor points on the floor.
    Using either a flat screwdriver or a socket unscrew the light cluster and then work out from the rear 2 x rubber grommet mountings also hold the light to the body so just wiggle the cluster out.Disconnect the cluster wiring harness. Do the same for the other side.
    3 x torx screws on each rear wheel arch, need a small wrench for this.
    2 x torx screws on the underside of the bumper towards the middle.
    1 x black torx and 1 x silver torx screws which are hidden by the light cluster.
    2 x 10mm nuts are holding the bumber to the rear of the vehicle, you need a long reach socket for the removal of these i bought one from halford's £4.99, i dipped the end of the socket in vaseline so the nut will stick to the socket when detached.
    Pull the bumper from the rear side above the wheel arch it is secured by push fit clips, once both sides are free from the body pull the bumper rearwards not upwards and it will clip out. Did mine today so its fresh in my mind.
    Refit is reverse.
    Dave
    audi58's Avatar
    Milton Keynes
    149
    Quote Originally Posted by Ninja21 View Post
    Refit is reverse.
    Dave
    Dave, you're a star!!
    This is highly appreciated.
    Previously Owned:
    Nov 2010
    348
    I guess it depends on the common sense and experience of the man with the toolkit........
    Mar 2011
    30
    Quote Originally Posted by Zafi View Post
    LOL and i missed one very important step see edited thread. Sorry
    Mar 2011
    30
    Quote Originally Posted by audi58 View Post
    No im not!! just realised that this post is in the A4 forum and my instructions are for the A3 very embarrassed......
    audi58's Avatar
    Milton Keynes
    149
    No worries, I had a go yesterday and managed to do it. It's very similar for the A4 however there are a couple of pins that need to be taken out near the light cluster.
    Thanks for your help anyway!
    Previously Owned:
    Nov 2010
    348
    I mentioned the pin, thought it was weird that Ninja did not.
    Did either of you drop a nut inside the rear light area
    Mar 2011
    30
    No dropping of nuts for me I use a trick of putting Vaseline all over the socket base so the nut sticks to it.
    21
    audi58's Avatar
    Milton Keynes
    149
    Haha, is was very careful! Luckily I did not.
    Thanks for all the info tho guys.
    Previously Owned:
    gaz j's Avatar
    Jan 2007
    Cheshire
    137
    Do the rear wheels have to be removed to remove the rear bumper? I've just bought the kit and was going to have a go at diy at the weekend, i've not had a look at how to remove bumper yet? How long did it take you to do the whole job?
    Nov 2010
    348
    If you have a 1/4 drive torx you dont need to remove the wheels.
    It takes about 15 minutes to do the first time. Need a torch the look into the rear light area for the almost hidden nut.
    If you have mydflaps its a bit more of a faff as they have a clip onto the arch that needs levering off and extra screws underneath.
    gaz j's Avatar
    Jan 2007
    Cheshire
    137
    Thanks for quick response,where is the pin and the screw behind panel (which panel)? And are these screws in light cluster on both sides?
    audi58's Avatar
    Milton Keynes
    149
    The pin will become viable when you take your light cluster off, it will be in the corner closest to the side of the car. The are screws on the underneath of the bumper and a nut each side of the car in a hole just below where you take the screw out for the light cluster.
    Previously Owned:
  1. Rear quarter window removal
    By 1animal1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st July 2010, 16:49
  2. rear quarter panel sections required
    By jcb in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd December 2008, 16:05
  3. S3 rear quarter panel damage! HELP
    By NISHS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2006, 16:28
  4. S3 rear quarter panel trim removal
    By NWMark in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2006, 09:08
  5. 96-01 rear quarter panel
    By brandona4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th August 2005, 03:40
