GNJBadger5
    Sep 2011
    6
    Post Thanks / Like
    a4 B8 SDS / Voice control questions ?
    I have my car A4 B8 with MMi 3G Nav kit which have SiM card slot. after insert SIM then telephone working fine , and bluetooth phone work also, my question is how can i know if this kit have voice control / SDS Control Module ? Due to when i press the PPT on wheel that give me information is "Button not used".
    BTW, i used VCDS 11.3 version try to check 77-telephone and 67 -voice control , but can not detect out Module, looks like have not those module , i read some related info on net said which can enable from 5F module by code. but i tested can not . (retrofit instructions: http://a6retrofit.tripod.com/article...cecontrol.html )
    Here is my 5F code: 010700000206EBEF77001F0D00000002
    J794 Part No. 8KD 035 670 B
    Thanks someone can help around !
    Best regards !
    Denis
    Sep 2011
    6
    Post Thanks / Like
    up up , thanks
