AWEsome GTIVAG Check
    Mar 2011
    22
    Post Thanks / Like
    S4 swapping tyres
    Has anyone been swapping their tyres between front and rear as recommended in the Manual? If so how often? While i am on the topic, how are your tyres wearing? Were they even between inside and outside?
    Essex, UK
    1,809
    Post Thanks / Like
    I'm on a 2.0T and running the 19"s....so not S4 but ...
    I've checked mine a couple of times and the wear has been equal so I've not swapped. I'm about due another check actually. Inside and outside and the same.
    B8 A4 Avant 2.0TFSI quattro S-line Executive
    Honda CBR1100XX Super Blackbird
    Gone : B6 S4 (AMD stage 3), TT (APR), Golf GTi, CBR600F
    Just Plain Old's Avatar
    Jun 2004
    Warwickshire
    1,220
    Post Thanks / Like
    Quite a bit of difference on mine.
    The rear drivers side has the least wear, and the worse is the passenger side front. The difference was 5mm.
    Swapping them diagonally seems to be the thing to do,, if you remember...........
    In my personal opinion
    Essex, UK
    1,809
    Post Thanks / Like
    Aren't they mostly directional tyres fitted though ?
    I'm sure it says in the manual not to do the diagonal swap.
    Jun 2004
    Warwickshire
    1,220
    Post Thanks / Like
    Not sure TBH. I use pirelli p zero, thinking about it though maybe they did just swap them front to back...?? But diagonally would be the right thing to do.
    Essex, UK
    1,809
    Post Thanks / Like
    "To ensure that the wear is equal on all tyres the wheels should be changed round from time to time according to the system Fig. 1. All the tyres will then last for about the same time."
