for a 2008 SE to be pricise. i have no c.control, ami, or 6cd changer.
LED rear turn signals? Is this a complete cluster replacement mod?
VCDS is a commercially available tool that can carry out many of the functions of the rather more expensive dealer tool, VAS.
Ross-Tech: Home
There are a whole host of 'functions' which can be modified or switched on/off to make changes to your car.
If you aren't confident with removing the steering wheel and airbag to change the stalk assembly then you'll be fine with the CC fit![]()
I've got a 2010 S0line car which has the LED rear clusters .... but only for the tail/brake lights. The turn signals (and fogs & reversing) are all normal bulbs .... and it bugged me A LOT !!!
I recently got some LED "bulbs" for the rear turn signals off ebay. Less that £3 delivered and they didn't throw a bulb out error (at least not yet!!)
