Sky InsuranceKowalski
Page 1 of 2 12 LastLast
Results 1 to 50 of 54
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,054
    Post Thanks / Like
    Accessing the hidden 3G MMI Menu
    There are several fora and websites which give info on how to access the hidden menu to activate other nice features however I found that the most widely publicised method didn't appear to work for me so after some googling and lots of reading I found an owner called Mike with a similar issue who had found a different method which he's kindly shared and I thought I post here for all in case you want it and to save searching.
    Firstly the secret menu must be enabled with VCDS beforehand.
    [5F - Information Electr.]
    [Adaptation - 10] -> Channel 6 -> Change 0 to 1
    Save and Exit.
    Next -
    Press/Release car (turns red)
    Press/Release setup (turns red)
    Press/Hold car & setup at same time for approx 6 seconds (setup button red light goes out)
    Release both buttons then press setup again.
    To exit the Hidden Menu you need to restart the MMI -
    Press and hold down the function keys (Setup), the control button (Joystick centre button) and the control key at the top right simultaneously until the MMI system shuts down. Release the keys and the MMI system reboots.
    Stu.
    A4 3.0 TDi S-Line Quattro, 7 Speed S-Tronic, Quartz Grey, 19" Twin Spoke Alloys, Alcantara with Silver Stitching & Heating, Nav High, B & O, AMI, DAB, Parking Advanced & Rear View Camera, Advanced Keyless Entry, LED Interior Light Pack, Hill Hold Assist, Heated Electric Folding Mirrors, Through Load.
    Previous MY11 S3 Sportback Black Edition, S-Tronic, Ibis White.
    Essex, UK
    1,809
    Post Thanks / Like
    So is the difference to normal that you are doing these first?
    Everything else seems the same.
    B8 A4 Avant 2.0TFSI quattro S-line Executive
    Honda CBR1100XX Super Blackbird
    Gone : B6 S4 (AMD stage 3), TT (APR), Golf GTi, CBR600F
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,054
    Post Thanks / Like
    Most other info suggests simply holding Car and Setup for 6 - 8 seconds would bring the menu on.
    Stu.
    Just Plain Old's Avatar
    Jun 2004
    Warwickshire
    1,220
    Post Thanks / Like
    Can I ask what the hidden 3G menu actually does??
    In my personal opinion
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,054
    Post Thanks / Like
    Here is a taster -
    AudiEnthusiasts Vag Com
    I've not tried it but apparently if you have the 3G and don't have Bluetooth fitted as an option it is actually fitted but not enabled.
    Stu.
    Jun 2004
    Warwickshire
    1,220
    Post Thanks / Like
    Thanks VRStu,
    I have bluetooth fitted, so is this something that is already enabled? Or is the 3G something else?? The link didn't give any detail. (unless I'm missing something! Always possible!)
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,054
    Post Thanks / Like
    If you already have BT then that part wouldn't apply. Yes you may have missed something, you should have a look at some of the links on that page if you are interested.
    Eg -
    TPM (A £65 option or free if you have the correct ABS controller) - AudiEnthusiasts TPMS
    Video in Motion - AudiEnthusiasts Master
    Needle Sweep - AudiEnthusiasts Vag Com
    Stu.
  9. Thanks wez3570 thanked for this post
  10. #8
    Jun 2004
    Warwickshire
    1,220
    Post Thanks / Like
    Yep,
    Thanks for that. I like the idea of enabling the TMP, and I have hill hold assist, so it should be do-able. Trouble is I don't have a VAGCOM?? Is that what it's called?
    Mind you I'd probably make a complete f**k up of it, so probably cheaper to pay dealer £65 for it!
  11. #9
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,054
    Post Thanks / Like
    So far so good -
    TPM activated
    Ambient Lighting Control activated
    Battery Level activated
    Dipping Rear View Mirror activated
    CD Ripping to Hard Disk activated - to be tested
    VIM activated - to be tested
    Stu.
  12. #10
    Keef's Avatar
    Jun 2006
    Brum
    255
    Post Thanks / Like
    As it requires a switch, I assume HHA cannot be activated via VCDS?
    Sounds like you know your onions when it comes to the settings - I must admit you’re a braver man than me, having a new car that’s less than one week old and tinkering with the settings!
    I managed to retrofit an Aux-in lead to the ford stereo in the wife’s focus on Saturday
    and was feeling pretty darn chuffed with myself - I suddenly feel very inadequate!
    I’m guessing the VCDS equipment cost is high?
    I look forward to reading more….
    Keef
    A4 Avant 3.0TDi quattro Black Edition, S-tronic, Quartz Grey, 19" 5-segment-spoke alloys, S line sports suspension,
    Black Milano leather, Heated front seats, Convenience pack, Tech Pack high, Power tailgate, Storage pack, Interior light pack,
    Tyre pressure monitoring.
  13. #11
    Essex, UK
    1,809
    Post Thanks / Like
    The hidden menu is required for quite a few tweaks but many are just done in VCDS (Vag-com)
    I've just checked to see what I've done. Errrm quite a few !
    Hidden Menu
    Lap timer/oil temp
    Needle sweep
    CD ripping
    DRL’s - no winking
    Ambient Lighting
    Battery Level
    Aux ventilation
    kerb lighting
    LEDs @ 50% with headlights
    Number of windscreen washes before headlight wash increased
    Auto brake off without seatbelt being on
    DVD playback when VIM
    Seatbelt warning disabled
    Reversing mirror dip
    Alarm Beep
    Emergency Brake light flash (not sure if it works)
    Default mode for Dynamic Modes changed to Idividual instead of Auto
    standby delay from 10 to 30 (time radio etc can be on with ignition off)
    DIS comsumption corrected
  14. #12
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,054
    Post Thanks / Like
    Looks like you have been a busy boy Scotty.
    I filled up for the first time today so DIS Correction may be on the cards soon.
    I've looked at pretty much all of what you have listed, most of which I don't think I need but that may change with time
    As you say Keef as the HHA on the A4 has a switch then it's more than a VCDS tweak but could be retrofittable.
    Stu.
  15. #13
    Essex, UK
    1,809
    Post Thanks / Like
    I've been tweaking B8s for a couple of years so it's not all been in one go. I've done many and then put them back. I liked the American taillights but haven't yet found a way to stop the Euro turn signal without getting a DIS error.
    Don't rush the DIS consumption correction. Mine varies with how I use the car and the amount it's out isn't consistent so you need a decent average.
    I'd love HHA as I had it on the 2009 B8 I had ..... but I can't see it being done for me as I have Stop / Start and apparently it's incompatible.
  16. #14
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,054
    Post Thanks / Like
    I tested the VIM last night which works flawlessly and the CD rip function is pretty good too.
    Stu.
  17. #15
    Essex, UK
    1,809
    Post Thanks / Like
    I think I'm about to find all my tweaks have gone. My car's currently at Audi having the latest maps and s/w put on and I know they've updated many modules in SVM which will have put back the factory codes.
    Still I guess it's more time for playing in the car
  18. #16
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,054
    Post Thanks / Like
    Interested to know what happens with your maps Scotty. Do they charge you for them?
    I'm a bit gutted there still isn't 7 digit postcodes, SAT, VW and Skoda have it on the RNS510 based units.
    Stu.
  19. #17
    Essex, UK
    1,809
    Post Thanks / Like
    No charge ..... but only coz it's an offer of goodwill.
    I got it due to two things.
    [1] I complained that my 3G wasn't working properly (the roundabout issue) when my 2G did. I said that since I'd had the car over a year and it still wasn't fixed that wasn't acceptable. My dealer said they'd try to get goodwill from Audi.
    [2] When my dealer applied the software fix for the above, it didn't go right and hence I got the car back with the same version prior to their attempt.
    After this I was told that as an offer of goodwill they'd do me a free map upgrade. This was back in October '10 and I could have had the March '10 update (my car/maps are Sep '09) or I could wait until the March release in 2011. I waited .... but Audi delayed the release of the update so it's only going on now.
    I'm not expecting much functionaolity change if any......and there won't be 7 digit postcode.
  20. #18
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,054
    Post Thanks / Like
    You'll have to let me know what version your maps are and I'll check mine.
    Stu.
  21. #19
    Essex, UK
    1,809
    Post Thanks / Like
  22. Thanks VRStu thanked for this post
  23. #20
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,054
    Post Thanks / Like
    Same maps as I have Scotty although I have a later MMI SW version HNav_EU_P0054_D1.
    Stu.
  24. Thanks scoTTy thanked for this post
  25. #21
    Essex, UK
    1,809
    Post Thanks / Like
    Weird !! It took them hours as they sad they were updating all the modules!
  26. #22
    Apr 2011
    195
    Post Thanks / Like
    map update takes 45 mins and unless they do a comparison test after then your tweeks will not be affected as this is not a mmi update but a map update
    p0054 is a factory release and no availability to update at dealer level as 0031 is the latest up datable release for the dealers
    if you have updated to 0031 then yes the svm will recode the 5f and wipe tweeks
  27. Thanks scoTTy, VRStu thanked for this post
  28. #23
    Essex, UK
    1,809
    Post Thanks / Like
    Thanks A8 Tech,
    I expected the tweaks to go as I didn't ask them not to leave them alone. Many stayed but many went. No worries.
    Initial feelings are that the roundabout issue is better but I've only driven about 20 miles. I've also got a some small clocks that pop up with "delays" etc.
    Do you have access to what's changed between versions? It always makes me wonder.
  29. #24
    Essex, UK
    1,809
    Post Thanks / Like
    And the instructions at roundabout still aren't correct !!!!
  30. #25
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,054
    Post Thanks / Like
    What's happening mate, I'll see if I notice it on mine.
    Stu.
  31. #26
    Apr 2011
    195
    Post Thanks / Like
    Quote Originally Posted by scoTTy View Post
    default mmi and then set up short voice tags and retry
  32. #27
    Essex, UK
    1,809
    Post Thanks / Like
    Quote Originally Posted by VRStu View Post
    If I'm turning right on a roudabout :
    "Take the third exit" (i.e take the exit at 3 o'clock)
    Just as I pass exit two (12'oclock) it says "Now take the second exit"....when it should be the first.
    Quote Originally Posted by a8 tech View Post
    I tried short voice tags on a previous version after my dealer suggested it and it didn't help but I'll definately try your suggestion and see what happens. Many thanks - I'll give it a go and report back.
  33. #28
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,054
    Post Thanks / Like
    I've not noticed on mine Scotty, tried it today.
    Perhaps you could push the dealer to replace the nav unit if they can't resolve it.
    Stu.
  34. #29
    Apr 2011
    195
    Post Thanks / Like
    if they replace it then only sw 0031 will be installed as the units come without the software installed.
    only the factory can update to 0054
    so it will not change anything and at £1900 ago its likely warranty will reject the dealers claim
    the update fixed every complaint I dealt with and also a car i tested for 1week after the update
    you may be able to dump screen the nav screen when the fault occurs to show the dealer who can then forward it to factory showing the problem with the gps info, road speed and distance before it commands now turn left
  35. Thanks VRStu thanked for this post
  36. #30
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,054
    Post Thanks / Like
    Just a thought but can you modify or correct the position of these Navs? I remember on the RNS-E and RNS510 etc you can adjust the car position etc. To check park on a cross roads or similar junction and see if the Nav places you in the same position.
    Stu.
  37. #31
    Essex, UK
    1,809
    Post Thanks / Like
    It's good to know you don't seem to have the issue as hopefully that means it's been adressed and just have to filter down.
    I think I'll make a video of it and see what Audi UK say. It's one thing paying through the nose for a satnav system but it's something else doing so when it doesn't fecking work !
  38. #32
    Apr 2011
    195
    Post Thanks / Like
    there should be a revised update for the newer 0054 3g software coming soon
  39. Thanks scoTTy thanked for this post
    Likes scoTTy liked this post
  40. #33
    Essex, UK
    1,809
    Post Thanks / Like
    Fingers crossed.
    I reset and changed the voice controls and the issues still there. I even got it going straight over a roundabout today.
  41. #34
    Trev241's Avatar
    Mar 2007
    184
    Post Thanks / Like
    Fingers crossed.
    I have the same problem my local dealer tells me that it's a minor software change from the factory to correct the issue, they have done quite a few.
    Trev
  42. #35
    Essex, UK
    1,809
    Post Thanks / Like
    The problem is definately still there on mine and I have the latest dealer release maps and software.
    Trev - please dive in and see what you can find. I'll admit to being a tad sceptical at the moment but also hopeful. A hopeful sceptic! Whatever next ?!?!
  43. #36
    Trev241's Avatar
    Mar 2007
    184
    Post Thanks / Like
    Gona book it in shortly, let you know what happens. By the way I think from memory I have an earlier version ending 0022 will check when next in car.
    I was going onto a roundabout yesterday and about to take first exit which she announced correctly, as I was about to turn she said "now take the second exit" don't know about you but I regularly swear at the bloody thing.
    Trev
  44. #37
    Essex, UK
    1,809
    Post Thanks / Like
    Audi C.S. just called me and were saying there's little they can do and it's best to tal to the dealer. I explained the situation and now it's gonna be passed onto someone who has more time to investigate. The guy I spoke to was first line and I think they have to do quick turnaround and get through a lot of calls. They don't have the chance to do research etc.
    I should be called back within 48 hours.
  45. #38
    VRStu's Avatar
    Just Looking
    Oct 2008
    Hampshire
    1,054
    Post Thanks / Like
    Fingers crossed they'll come up with a solution.
    Stu.
  46. #39
    Sep 2011
    6
    Post Thanks / Like
    Maybe someone can help me this , I have my car A4 B8 with MMi 3G Nav kit which have SiM card slot. after insert SIM then telephone working fine , and bluetooth phone work also, my question is how can i know if this kit have voice control / SDS Control Module ? Due to when i press the PPT on wheel that give me information is "Button not used".
    BTW, i used VCDS 11.3 version try to check 77-telephone and 67 -voice control , but can not detect out Module, looks like have not those module , i read some related info on net said which can enable from 5F module by code. but i tested can not . (retrofit instructions: http://a6retrofit.tripod.com/article...cecontrol.html )
    Here is my 5F code: 010700000206EBEF77001F0D00000002
    J794 Part No. 8KD 035 670 B
    Thanks someone can help around !
    Best regards !
    Denis
  47. #40
    Sep 2011
    6
    Post Thanks / Like
    information is "Button not used".<br>
    <br>
    module by code. but i tested can not . (retrofit instructions: <a href="http://a6retrofit.tripod.com/articles/a4a5a6voicecontrol.html" target="_blank">http://a6retrofit.tripod.com/article...cecontrol.html</a> )<br>
    <br>
    Here is my 5F code: 010700000206EBEF77001F0D00000002<br>
    <br>
    J794 Part No. 8KD 035 670 B<br>
    <br>
    Thanks someone can help around !<br>
    <br>
    <br>
    Best regards !<br>
    <br>
    <br>
    Denis
  48. #41
    Apr 2011
    195
    Post Thanks / Like
    77 is within 5f
    Unsure what your asking, have you retro fitted 3g or activated the phone
    push to talk should work or look at address 16 coding
  49. #42
    Sep 2011
    6
    Post Thanks / Like
    77 is within 5f
    hi , thanks for your reply .the phone was working fine via bluetooth or direct insert my sim card into slot. my address 16 streering wheel (J527) coding is 00003E, the part no. SW is 8K0 953 568 G. should i change the code from 16 ?
    Best regards !
    Denis
  50. #43
    Jun 2011
    Post Thanks / Like
    Anyone knows about 2G? Can we enable the oil temp meter? Or there is no oil temp for 2G? Thanks
    Save and Exit.
    Next -
  51. #44
    Aug 2011
    21
    Post Thanks / Like
    Tapping the wealth of knowledge on here............what is the function of 3G ? Is it a standard fit or only available with BT and or Sat Nav ? Trying to suss what goodies to look out for when I eventually see the right car ..........................Soon I hope
  52. #45
    Essex, UK
    1,809
    Post Thanks / Like
    3G simply refers to the MMI being the 3rd Generation. It's not a function in itself.
    You get better screen resolution, quicker response, 3D images on the Satnav etc etc
    3G came in with the MY2010 models around July 2009. Beware that even if you buy a car with satnav after this date it may not be the full thing as the DVD based satnav was still available. The easiest way to tell is ;
    Non satnav car :
    2G Satnav cars have the MMI rotaty controller down by the arm test.
    3G satnav cars have a little thumb joystick on the top of the MMI rotary controller.
  53. Thanks clansman thanked for this post
  54. #46
    Aug 2011
    21
    Post Thanks / Like
    Cheers scoTTy that has cleared the fog a bit ! I think I have a hell of a lot to get to grips with here LOL. The car I have come across is an 09 but not sure how far in to 09 it was registered/manufactured, have e-mailed the dealer to ask so lets hope he know what it is !!!
  55. #47
    Aug 2011
    21
    Post Thanks / Like
    [IMG][/IMG]
    [IMG][/IMG]
    This is the interior I am thinking it is only a 2G unit!?
  56. #48
    Essex, UK
    1,809
    Post Thanks / Like
    Hard to tell from that pic. You should be aware that the changes for the MY2010 cars were quite a lot. At least a lot more in any year before or since. Check out this document :
    http://dl.dropbox.com/u/3628815/Car/...nd pricing.doc
    Personally I'd try and get the later car due to the benefits not least the quieter wing mirrors.
    Not sure what the above one is though. I suspect an earlier car based on the glimpse of the mirrors. Also since it's a manual, if it's a 2.0T or a 2.0TDI then it's an earlier car as the later ones have Stop/Start and a button under the coin holder (the slot thing near the gear shift).
  57. #49
    Aug 2011
    21
    Post Thanks / Like
    [IMG][/IMG]
    Any help?
    Oh and thanks for the link............yeah I am thinking along that line too
  58. #50
    Essex, UK
    1,809
    Post Thanks / Like
    I'd say it's MY2009 but during transition there's always a few off build cars.
    Simple thing is to ask the dealer
