Chris NottSky Insurance
Page 2 of 2 FirstFirst 12
Results 41 to 60 of 60
Like Tree1Likes
Thread: Accessing the hidden 3G MMI Menu
  1. #41
    Apr 2011
    197
    77 is within 5f
    Unsure what your asking, have you retro fitted 3g or activated the phone
    push to talk should work or look at address 16 coding
  3. #42
    Sep 2011
    6
    Quote Originally Posted by a8 tech View Post
    77 is within 5f
    hi , thanks for your reply .the phone was working fine via bluetooth or direct insert my sim card into slot. my address 16 streering wheel (J527) coding is 00003E, the part no. SW is 8K0 953 568 G. should i change the code from 16 ?
    Best regards !
    Denis
  4. #43
    Jun 2011
    Anyone knows about 2G? Can we enable the oil temp meter? Or there is no oil temp for 2G? Thanks
    Quote Originally Posted by VRStu View Post
    There are several fora and websites which give info on how to access the hidden menu to activate other nice features however I found that the most widely publicised method didn't appear to work for me so after some googling and lots of reading I found an owner called Mike with a similar issue who had found a different method which he's kindly shared and I thought I post here for all in case you want it and to save searching.
    Firstly the secret menu must be enabled with VCDS beforehand.
    [5F - Information Electr.]
    [Adaptation - 10] -> Channel 6 -> Change 0 to 1
    Save and Exit.
    Next -
    Press/Release car (turns red)
    Press/Release setup (turns red)
    Press/Hold car & setup at same time for approx 6 seconds (setup button red light goes out)
    Release both buttons then press setup again.
    To exit the Hidden Menu you need to restart the MMI -
    Press and hold down the function keys (Setup), the control button (Joystick centre button) and the control key at the top right simultaneously until the MMI system shuts down. Release the keys and the MMI system reboots.
  5. #44
    Aug 2011
    21
    Tapping the wealth of knowledge on here............what is the function of 3G ? Is it a standard fit or only available with BT and or Sat Nav ? Trying to suss what goodies to look out for when I eventually see the right car ..........................Soon I hope
  6. #45
    scoTTy's Avatar
    Essex, UK
    1,958
    3G simply refers to the MMI being the 3rd Generation. It's not a function in itself.
    You get better screen resolution, quicker response, 3D images on the Satnav etc etc
    3G came in with the MY2010 models around July 2009. Beware that even if you buy a car with satnav after this date it may not be the full thing as the DVD based satnav was still available. The easiest way to tell is ;
    Non satnav car :
    2G Satnav cars have the MMI rotaty controller down by the arm test.
    3G satnav cars have a little thumb joystick on the top of the MMI rotary controller.
    MY2010 B8 A4 Avant 2.0TFSI quattro S-line Executive
    Honda CBR1100XX Super Blackbird
    Gone : B6 S4 (AMD stage 3), TT (APR), Golf GTi, CBR600F
  7. #46
    Aug 2011
    21
    Cheers scoTTy that has cleared the fog a bit ! I think I have a hell of a lot to get to grips with here LOL. The car I have come across is an 09 but not sure how far in to 09 it was registered/manufactured, have e-mailed the dealer to ask so lets hope he know what it is !!!
  8. #47
    Aug 2011
    21
    [IMG][/IMG]
    [IMG][/IMG]
    This is the interior I am thinking it is only a 2G unit!?
  9. #48
    scoTTy's Avatar
    Essex, UK
    1,958
    Hard to tell from that pic. You should be aware that the changes for the MY2010 cars were quite a lot. At least a lot more in any year before or since. Check out this document :
    http://dl.dropbox.com/u/3628815/Car/...nd pricing.doc
    Personally I'd try and get the later car due to the benefits not least the quieter wing mirrors.
    Not sure what the above one is though. I suspect an earlier car based on the glimpse of the mirrors. Also since it's a manual, if it's a 2.0T or a 2.0TDI then it's an earlier car as the later ones have Stop/Start and a button under the coin holder (the slot thing near the gear shift).
  10. #49
    Aug 2011
    21
    [IMG][/IMG]
    Any help?
    Oh and thanks for the link............yeah I am thinking along that line too
  11. #50
    scoTTy's Avatar
    Essex, UK
    1,958
    I'd say it's MY2009 but during transition there's always a few off build cars.
    Simple thing is to ask the dealer
  12. #51
    Aug 2011
    21
    He confirmed it is a 2G model, not sure if it is possible to "upgrade " to 3G ? If that is possible then could be a green for go
  13. #52
    scoTTy's Avatar
    Essex, UK
    1,958
    Technically it is but financially it isn't. Once you've thrown the £3k+ at it then it's obviously worth just buying a newer car.
  14. #53
    Aug 2011
    21
    3K !!! That's a lot of Tom Toms LOL....... I get the picture now thanks for the heads up scoTTy..............again
  15. #54
    Sep 2011
    6
    Anyone can help my question above ? i am still looking for this SDS function , thanks
  16. #55
    Jan 2011
    Chesterfield
    80
    Add evans1089 on Facebook
    I cannot access the controller.. Keeps saying there's no response from controller. Any ideas why?
  17. #56
    2,150
    Do you which MMI is fitted to you car is it 3G or 2G? Can you access controller 07
  18. #57
    Jan 2011
    Chesterfield
    80
    No, won't let me access it, looking at a couple of pictures, I think I have 2G non Nav..
  19. #58
    2,150
    If you don't have navigation then you won't be able to access the 5F module as it will not be fitted to your car.
  20. #59
    Jan 2011
    Chesterfield
    80
    Quote Originally Posted by B5NUT View Post
    Oh I see! Thanks so for all the VCDS mods that require activation of the hidden menu, impossible for me?
  21. #60
    2,150
    It's only for MMI 3G systems, that have navigation with the 5F module installed.
    evans1089 likes this.
