Factory Fitted Detachable Towbar Pics please
turrican
NULL
Hi, Have ordered a Avant BE with detachable towbar and was wondering if anyone had pictures with the factory fitted towbar off. Want to see how much is still visible.
Is the westfalia going to be same as a factory fit? If so then that looks good.
rhino7 has posted pics of his aftermarket install of the Westfalia here -
http://www.audi-sport.net/vb/audi-s4-a4-a4-cab-b8-chassis/113479-a4-avant-s-line-tow-bar-coding.html
I think I'm going to fit one of these myself when the car arrives.
Westfalia Detachable Bar and & Westafalia Dedicated Electrics. Looks to be about £300 all in.
The S-Line (not sure about others) comes with towing prep as standard :eyebrows:
So it looks like a matter of making all the connections in the boot, so no running of cables throughout the car, and then some coding.
Thanks to rhino7 the coding details are -
I finally got around to getting this sorted out at the dealers. Afterwards I used VCDS to see what changes had been made to my 2010 S-Line Avant TDI:
[01 - Engine]
[Coding - 07]->[Long Coding Helper]->Byte 4, Bits 0-3 Changed from 0011 to 0100
[01 - Engine]
[Coding - 07]->[Long Coding Helper]->Byte 5, Bit 4 Changed from 0 to 1
(via check box "Trailer Installed" in VCDS)
[03 - ABS Brakes][Security Access - 16] (Enter code presented by program)
[Coding - 07]->[Long Coding Helper]->Byte 1, Bit 7 Changed from 0 to 1
(via check box "Trailer Hitch Installed" in VCDS)
[09 - Central Elec]
[Coding - 07]->[Long Coding Helper]->Byte 18, Bit 5 Changed from 0 to 1
[10 - Park / Steer Assist]
[Coding - 07]->[Long Coding Helper]->Byte 0, Bits 0-3 Changed from 0000 to 0001 [Trailer Hitch Not Installed to Trailer Hitch Installed (Manually Removable) via pull-down list in VCDS]
[5F - Information Elec]
[Coding - 07]->[Long Coding Helper]->Byte 10, Bit 5 Changed from 0 to 1
[19 - CAN Gateway]->[Installation List]->Tick 69 - Trailer
Hope this is useful to others!
