EM TuningJMB Retrofits
Results 1 to 8 of 8
    Maq
    Maq's Avatar
    Quattro_AvQ
    LONDON
    90
    Balancing or Alignment, or Both?
    Been a few weeks ivehad my car lowered and had my new 18's fitted. Was driving back from Goodwood and doing some speed on the empty roads, at about 70+ was getting a bit of vibration through the steering, didnt feel comfortable going over 80 as the car didnt feel too stable. Im sure i need wheel balancing, but dont know about Alignment. Thinking of getting balancing done, then checking if the problem persists before i have alignment done. Any Suggestions?.. Thanks
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    The garage will normally check alignment for free and only charge if it needs adjusting, so you may aswell get it done
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    Maq
    Maq's Avatar
    Quattro_AvQ
    LONDON
    90
    I think every garage woud say you need to have it done!...
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Probably, what's your point??? Most garages, you can see the results. The other option is to fork out thousands on the equipment and do it yourself if you don't trust anyone else.
    RNS-E retrofitted
    jon1982's Avatar
    diesel dodger
    Jul 2009
    wakefield
    119
    i have this problem with my car at 70+ mph, alignment is spot on, had 2 new tyres on this year so fronts are balanced spot on, the rears have,nt had new tyres or been balanced since ive owned the car, could it be the rear tyre balancing causing the vibration because someone told me it could,nt be the rear tyres???? i hope they,re wrong otherwise whats causing it
    s-line stu's Avatar
    West Midlands
    183
    I have also had this problem before and it does seem to be down to balancing the wheels - even the backs as it was the backs that were out on mine and this was with new tyres so the garage can't have balanced them particularly well when they put the tyres on.
    The car seems to be quite particular about wheel balance and even if it's only slightly out I get very slight vibration but if it's spot on the vibration goes.
    solaris's Avatar
    Slough, Berkshire
    404
    The first step would be to get the following checked out:-
    Tyre pressure
    Wheel balancing
    Wheel alignment (including camber & castor)
    If it's not longitudinal and it's not Quattro..it's not an Audi
    VCDS (VAG-COM) HEX-CAN USB cable carrying member
    2005 A4 DTM 2.0 TFSi Quattro :364Bhp/477NM - Mapped by MRC Tuning
    Hybrid K04 Project ongoing (link to Build thread)
    DMFW + Clutch For Sale
    Maq
    Maq's Avatar
    Quattro_AvQ
    LONDON
    90
    The problem has gone, jus needed tracking on the front 2 wheels...now it flys to 100 with ease and no hesitation!
