Chris NottAH Fabrications
Results 1 to 14 of 14
    Bigman's Avatar
    Cornish and Proud!
    Mar 2007
    Nuneaton, Warwickshire
    85
    Any viewing tips for a 2.0TFSI?
    Hey guys
    After my original plan of buying a 1.8t B6, I mave managed to stretch my budget a little and I am pretty set on getting an B7 Avant 2.0TFSI. Are there any tips on what I should be looking for when I go for look/drive? After owning a diesel for the past 3 years and only ever realy working on diesel engines the whole petrol thing is a little new to me. Also is there any known B7 bugs that i should look out for, The cars I am looking at are likely to be around the 100K mark.
    Adam
    gaz j's Avatar
    Jan 2007
    Cheshire
    137
    Be ready to put as much oil in as you do petrol! I've got a 56plate 2.0T s-line se(220) on 45k miles and im forever topping up on oil. Although the petrol mpg is brilliant, it burns oil really quick and mine car only does 10k miles per year. My mate's just got a brand new A5 with same engine and his is the same. My 2 previous motors where B6 1.8T's a 163 and a 190 Sport and i only ever used to top up oil once a year from what i remember. But apart from that its a Great engine, ha ha. Aside from that i'd still rather have a 2.0T over a 1.8T anyday. Its a lot better on fuel,cheaper road tax, and power delivery much better.
    2.0 Tdi S-Line 143. Remap 180 bhp/290lb torque.
    Jan 2004
    York
    1,657
    Quote Originally Posted by gaz j View Post
    The A5 2.0T engines are NOT the same as the B7 2.0T. The A5s run the new valve lift incarnation of the 2.0T. The 220ps in the B7 A4 is just a half hearted remapped version of the orig 2.0T
    MY15 8V S3 Sportback with options
    Nov 2006
    52
    I had a 2tfsi quattro se for four years and only topped up the oil two or three times in 30,000 miles apart from servicing. The only fault I had was the sychromesh on second gear went,it took Witherspoons in Edinburgh six weeks to fix under warranty.
    gaz j's Avatar
    Jan 2007
    Cheshire
    137
    "The A5 2.0T engines are NOT the same as the B7 2.0T. The A5s run the new valve lift incarnation of the 2.0T. The 220ps in the B7 A4 is just a half hearted remapped version of the orig 2.0T." It still burns lots of oil like mine, which is my point anyway. But don't be put off by that, I love mine and every car is different,maybe they don't all burn oil but my mate who works at Audi said they've had a lot back in with customers complaining of oil consumption.
    hazey7's Avatar
    Sep 2009
    170
    My mates an experienced mechanic and its down to two things:
    1. How well the car was run in from new - if the running in wasn't carried out carefully and properly the rings (particularly the oil scraper ring) won't seal as well as they could so you'll always burn some oil.
    2: The 5W 30 oil is so thin its bound to partially evaporate/burn off/get used.... so yeah, some consumption is to be expected....... depends on who you speak to!! If you used 20W/50 like we did 20 years ago you wouldn't be using oil like these engines do.
    That's my two penneth.....
    Mine has used 1.5 litres in 10,000 miles.
    Jan 2004
    York
    1,657
    Quote Originally Posted by hazey7 View Post
    The reasons these engines do are because tollerances are so much finer, using 20W/50 now would just feck the engine no end.
    solaris's Avatar
    Slough, Berkshire
    404
    Hi,
    A couple of things to check:-
    1. You need to check with the owner if the Diverter valve has been uprated to the revised piston type. The old ones are diaphragm based and can rip causing boost leak.
    2. Check if the Cam follower has been inspected as these are prone to wear and can do some serious damage if they fail.
    If it's not longitudinal and it's not Quattro..it's not an Audi
    VCDS (VAG-COM) HEX-CAN USB cable carrying member
    2005 A4 DTM 2.0 TFSi Quattro :364Bhp/477NM - Mapped by MRC Tuning
    Hybrid K04 Project ongoing (link to Build thread)
    DMFW + Clutch For Sale
    Jul 2009
    London
    60
    Yes do check the Cam follower!!!
    I took my car in to Backdraft for a service and also due to low fuel pressure, they did service charged me 65 for a diagnostic chediesck showing low fuel pressure on rail 1 and 2, they also claim to have checked cam follower yet 3 months later just as i was intending to sell my car, bang car dies and restarts for two seconds and stops!
    taken by AA to Audi who confirmed dreaded fuel follower completley knackered and cam as well!!!
    2400 later car back and better than ever, Backdraft's answer to me when i challenged them....... we checked the follower and will swear in court if need be! course you did!
    A4 DTM Revo 2, Miltek turbo back, RS4 ARB, Forge dv. 290 bhp on a cold day!
    Bigman's Avatar
    Cornish and Proud!
    Mar 2007
    85
    Thanks for the Replies guys, Unfortunatly I did not see the last 2 postes, but I have bought the car so I will get those things checked out ASAP!
    Here it is, 2006 (55plate) 2.0TFSI, REALY happy with it!
    Adam
    gaz j's Avatar
    Jan 2007
    Cheshire
    137
    Nice Motor, you wont be dissapointed.
    jey
    jey's Avatar
    Nov 2007
    228
    mine burns oil also. sister inlaws 09tt also burns oil as bad! sync mesh was cause of gear wear which was fixed under warranty. dv valve needs replaced. clutch now slipping on and off lol all happened between 40 and 48k miles. there a great car looking and driving but full of probs! id 03 b6 which timing went in engine and needed all upper engine replaced, it was a 2.0 fsi engine....
    Audi A5 Sport With Full Sline Kit, Milltek Full System, ITG Filter, 20" Wheels, Sat Nav, DAB, TV, All Voice Controlled, Folding Mirrors, Auto Dim Mirrors, Ipod Connection, Bluetooth, Car Phone, Electric Leather Memory Seats. B&O Sound System.
    Jul 2009
    London
    60
    anyone else suffered the cam follower nighmare?
    really think needs it needs to be made more aware!
    Jan 2004
    York
    1,657
    I've check my 56 plate and mine looks almost brand new. Mind you, car's only done 24K miles since new.
